Crown under pressure
Hi all very very new to this. I have a couple of watches that I guess are over wound .now these are play watches for me to take apart and rebuild . The crown will turn less than a quarter and then returns to its previous position under load. What would the possible causes be.what should I look for while stripping . Neither have any complications
Hi there (from one newbie to another) It's very difficult to overwind a watch, you would have to put lots of pressure on the winder to rip the mainspring from the wall of the barrel. The usual reason is the watch has already been wound up but won't work because it generally needs cleaning and has given up the ghost.
There are lots of lovely videos to get you started on your own watch with a handful of tools to start. Good luck
Edited by OCSfan
Predicted text
At the rate I’m buying tools I could have purchased the watch I really want . The broken watch is a little smiths astral. Looked bigger in the picture . Likes Luke a nightmare to practice on. Hey ho . Here we go
Look for them to simply be watches that aren’t running, usually from lack of service but any other reason is possible. Technically there is no such thing as overwound. What happens is a watch quits running and everyone who picks it up tries to wind it, and eventually it is wound as tight as it can be. Then later someone picks it up and thinks , oh, it’s overwound and that wasn’t the case. Make sense?
Sent from my iPad using Tapatalk Pro
What movements do these watches have ? Most movements can have the mainspring release its power reserve. You have to do it gently and the way you do it depends for many movements.
This is the Ops movement. Can't identify it but looks a pretty standard affair. Release by lifting the click and letting fitted crown and stem revolve between finger and thumb slowly until mainspring is unwound or use a well fitting screwdriver on the mainspring wheel until unwound.
Really suggest the OP goes on YouTube first and find some videos of this being done before attempting themself. a18213b9e0f68c0ef7b6cd2ae8307f62.jpg
Sent from my SM-T585 using Tapatalk
It should be stressed this is often tricky (you can think you have a good grip on the crown or what have you and it starts turning and unwinding rapidly when you least expect it) and if too much power is let down too quickly it can cause damage to the movement. That being said it is 'simple' and a key thing you need to practice in watch repair, always make sure the mainspring is let down before starting any disassembly. Good luck.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
