ETA 2836-2 Auto Mechanism Issue
Dico
Hello All,
I just serviced an ETA 2836-2 which runs flawlessly up until the auto mechanism is put back on. Without the auto mechanism it runs almost a full 36 hours when fully wound but once the auto mechanism is on it stops intermittently every few hours even when its sitting still. The mechanism is seated correctly and I verified nothing is interfering with the balance. Any thoughts on what can be causing this?
Yup, this is a classic eta issue.. firstly, the rotor and reversing wheels must be as clean as physically possible..
the rotor bearing requires a very small drop of oil on 1 or 2 of the balls
each reversing wheel requires the smallest possible oil on the tip of each pawl where it contacts the mating locking surface inside the wheel, and possibly a miniscule drop between the wheel arbor and the free running wheel of the reverser (hard to describe, and sometimes this doesnt work)
I use 9010 to lubricate these, after epilaming, to make sure the oil doesn't sod off to places I don't want it ;-)
if after doing this, demagnetising, and it still makes the rotor "propellor", clean them, repeat the process and don't be surprised if you need to do it a 3rd time ;-)
if you do make it to the 3rd time, the reversing wheel may need replacing..
Tom
The Lubeta is meant to work well, unfortunately getting a single bottle of it into Australia is prohibitively expensive ($4-500) due to hazardous material charges.. the 9010 is what is used at the swatch group service centre here, and more easily available.
The lubeta does also leave a white non-uniform residue over the entire part, so isn't appropriate for watches with a visible movement.
Tom
Hi All,
So over the past 2 weeks or so I've tried cleaning and oiling the auto mechanism 3 different times...that didn't work
Change out the rotor completely to a brand new one....that didn't work
Change the whole auto mechanism including rotor to a new one....and that didn't work
I'm at a loss here....is there anything else that can be causing this god forsaken watch to stop ONLY when an auto mechanism is re-attached to it??
:startle:
Oops, I just realized you meant the main movement was stopping, I was just thinking you hadn't got the auto winding properly...
Check anywhere there might be a pivot being interfered with, (centre seconds is a common one if the second hand has been put on without supporting the jewel), that the train bridge is flat, and not being pressed on by the auto bridge, also where the auto transmission wheel post goes into the barrel bridge, there's an opportunity for pressure...
Another one that just came to mind, make sure the auto bridge isn't pressing on the regulator on the balance cock...
Tom
If the watch still runs for 36 hours without the auto then it is still the auto or auto assembly that is the issue. I have read many times that most auto wheels run better not being lubricated just cleaned. ETA developed Lubeta to address this but I would be very surprised if this was the issue. I would say it is a assembly issue. Is it possible to a post a pic or even better a short vid of the movement running and the auto rotation.
Thank you for all the great responses. Taking the advice of clockboy I’ve included 2 short videos so you all can see the movement, screws and how things are seated. In this condition shown in the video, the watch runs flawlessly.
As soon as the rotor is placed on it again it stops within 12 hours. I’ll post another video with the rotor attached. I’ve changed the whole auto assembly to a new one so I don’t think the issue is there. It must be something else. Could the mainspring barrel cause this?
7CAE1615-DF00-49CD-B7F8-B75405400A15.MOV
BD73A76B-151D-4C8C-924E-67262647F793.MOV
Hi everyone
Still having the same issue here. I noticed after the last video I posted that even after winding a few times the balance does not start moving. In fact I have to shake the watch to get it going and then it’s fine as long as rotor is off. Can that have anything to do with the stopping issue I’m encountering? Issue with the barrel?
Hi All,
I'm still troubleshooting here. Noticed when it stops its always at the 51 or 52 second mark. The hours in between are random could be as little as 10 mins or as much as 12 hours - but always stops at about the same seconds mark. What does this mean??
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
