Today I got this Omega Constellation I have never seen before, around late 70's? It has kind of octagonal shape and has a quartz movement with quicksetting. As the back is already damaged by the previous owner, I wonder how to open this one without further damaging it as I would like to know which caliber is inside. Appreciate your help guys.
It has a snap off case back. That means you have to pry it open. Do you have a case back knife ? You could also use a knife with a thin (but durable) blade that isn't sharp or pointy so that you won't damage the case.
Look for a small slot/space somewhere along the case back as that is where you should insert the knife. Unfortunately not all watches have that...
You can also try to use a rubber ball and rotate it around a bit to free it from potential gunk and afterwards pry it open but that won't always help.
Edited by Chopin
In addition: The minute hand is set by turning the crown as usual but the hour hand is set by pushing in the middle of the crown. The hand then will run forward.
thanks Chopin...there is no space whatsoever, I guess that explains all the scratches on the side of the caseback. I will give it a go with the squeezeeball, see if it turns a bit.
You can buff off the scratches. Just tape out the brushed part as that is more difficult to repair.
Edited by jdm
  • 2 months later...
Hi, i'm a total newbie here.
I have exactly the same watch, which my partner bought for me as a birthday present about 4 years ago now.
However, unfortunately i have never worn it because it isn't complete. He thought it would be quite easy to source a dial and hands for the 1330 and this watch case. To complete it.
But it has proven harder than we thought. Can you help in any way as to where i can get a dial for this watch, hands etc. i have tried many a dial that is the right size as the case however they are not compatible with the case.
I would love to be able to wear this watch. I love it so much.
Any help or advice would be gratefully received..
Many thanks in advance.
Welcome and good luck sourcing the parts.
You could send a message to
http://www.ofrei.com/page665.html
And ask availability.
Or if you are in the UK then try Cousinsuk.com
You will need to provide the case number which is inside the caseback - probably  395.0802 if the same as the watch above. Alternatively you could try one of these items from eBay which have case, dial and hands:
182937592182
162781970733
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
    • Thanks for the reply. I polished the head of the screw using 1500 to 10000 lapping paper and a screw polisher. This is why I think the head blued and the rest of the screw didn't. Silly question, how do you polish the whole screw inc threads, if that's what it needs to blue? 100% clean, Elna red and heated ultrasonic bath + IPA rinse. Finally, there is definitely heat leak as there's about a 30c difference between the brass bed and the soldering station temp. Having said that, the bed temp was stable. I will try to search out a better brass pot, but I haven't found one yet, hence the stainless steel bowl.
    • Agreed but that's where WD40 excels, water displacement.
    • I would change the container to a thick walled brass one to start with. Looking at you screw pictures they don’t look shiny enough, really it’s best to do a black polish on them before trying. Also make sure once polished they are scrupulously clean, I dunk my experiments in acetone before bluing.   i think the thin walled stainless container to leach away the heat from the shavings, most successful bluing videos for example use thick walled brass to hold a good deep amount of shavings which acts as a better holder of heat.   Tom
    • …I guess my friend’s dad was duped…and by a Rolex dealer… …well, it’s a good fake 🤪 even the box and papers look legit…
