Longines 291(?) help
Chopin
I have the opportunity to buy a lovely Longines watch but I'd like to know if this is an easy fix. Seller only says that a screw is missing from the oscillating weight and that that's why it's not installed on the movement.
I'm not sure how this one works and how it stays on the movement and I also feel like I see a screw on the weight in the picture. Could someone shed some light on this ? Should the weight have another component that goes into the slot or is just a screw necessary ?
There is a screw on the weight near the movement and I see it in the picture but I assume that's not what we're talking about...
Also, is this even a cal 291 or something else ?
Is the circle in the bag, around the weight, even part of all this ? Could it be some sort of a ring for the movement ? Doesn't seem like it...
Edited by Chopin
It is a calibre 291 the rotor sits on a post at the centre of the movement and the screw on the rotor is used to secure it to the post. It is probably the rotor post that has broken, these are listed as obsolete on the cousins web site, it is a common problem with this movement I dont know if any other supplier would hold this particular part. The ring looks like a tension ring from a watch crystal and is not a part of the movement such as a movement spacer ring as this one is held in place with clamps
Is this post a separate part that gets screwed/attached onto the movement and then you attach the weight or is it attached to the weight itself ?
It's most likely hard to find so only solution would be a donor movement...
Edited by Chopin
Yes the post is a separate part that is secured with two screws from the under side of the bridge, why not ask for clarification from the seller as to what part is missing or broken if its just one of the screws that holds the rotor post in place it should be easy enough to find a suitable one to use but if it is the post that broken then you will have trouble finding one as you say the way to go would be a donor movement but that may start to make the good price look a little less appealing
Seller doesn't seem knowledgeable. I got another picture from him. Is that the post ? Not the best picture sadly...
I think I can see a screw and a missing one... Am I wrong ? Do you have to detach it from the weight to install it onto the movement ? I see no other way...
Edited by Chopin
It's a real pity because looking the movement it is in really good condition apart from the screw or post has been broken. The 291 is obsolete so its up for sale.
No the post sits directly in the middle of the movement and is not part or the rotor itself. If the watch is very cheap I would take a punt and factor in the cost of a donor movement if its only slightly cheaper than a  runner walk away.
If it is just the post it should be possible to make one,  if you have a lathe that is !!!
So, basically, there should be another part between the movement and the rotor right ? I was hoping that the thing on the underside of the rotor might be it but I guess it's not... Wish I could find a schematic of the movement and see what that part looks like...
No lathe. Not that advanced I'm afraid...
Edited by Chopin
Is it this one below ? I keep finding it listed for other calibers so I guess it might be interchangeable... Very pricey sadly.
This part should replace the one marked axle by @wls1971 right ? I'm assuming you remove the top plate, install the new one, put the plate back and then screw it in place with those 2 screws and then the rotor... ?
I wonder if there's a chance that it might not be broken and it's just missing the screws...Only close up shot I have.
Edited by Chopin
25 minutes ago, rogart63 said:
Is the 290 post the same as the 291. I now where you can find one. Send me a PM and i can give you the contact.
Yes calibre 290 no date calibre 291 addition of date at either 12 o'clock or at 3 o'clock
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
