Longines
chrisdt
Someone who knows I like messing with watches has asked me to look at his Longines wind up watch. For obvious reasons I only work on MY OWN watches but as he's a friend I said I will have look at it for him and he's assured me he wont hold me responsible for any damage incurred. The problem is winding. The crown is in good order but it feels very stiff and difficult to wind although with effort it can be done. Other than that it runs perfectly and keeps time. Before I start dismantling could anyone advise me what to look for. Could it perhaps be cured without dismantling?
Chris
Hi Chris,
You might get a clue as to the problem when you attempt to remove the stem from the watch. If it's really tight or it's obvious that the stem seal has disintegrated / bent / corroded and is clogging things up, you may get away with replacing the seal and popping the stem back in.
However, the way these things normally run is that after stem removal and inspection you notice several issues associated with the crown wheel, stem, barre arbour or other things too.
So, I'd suggest disassembly will be necessary most of the time to get to the route of the problem!
Andy
Hello there,
Here is an exploded view of the setting and winding mechanism on a mechanical watch:
If the watch has a stiff feel when winding, it is likely an issue with the clutch wheel, setting wheel and/or the clutch lever. All of these parts need lubrication with moebius 9501 grease (the blue one). This cannot be remedied without uncasing the movement and removing the hands and dial to get to the keyless works.
Stiff winding is usually in the crown. As SKEXIS says it probably has a damaged seal. O-ring gasket is either stiff or gooey . You can get away with cleaning the old gasket out but a new crown is the best. If you just clean the old gasket out the watch will not be waterproof anymore. But sometimes people don't want the Longines or Omega crowns to be replaced.
If it is a new[er] Longines, then it would have an O-ring gasket in the crown, if its an older or dress watch, it's unlikely have an O-ring gasket in the crown.
J
Most crown gaskets can be replaced.
Most of the watches I've worked on wouldn't know water a gasket was. When I've encountered winding issues it's always been a build up of crud in the keyless works, no lubrication and usually always neglect of the mainspring and associated components.
This watch just probably needs a good servce
Sent from my SM-T585 using Tapatalk
5 hours ago, digginstony said:
Most of the watches I've worked ooleheartdelyn wouldn't know water a gasket was. When I've encountered winding issues it's always been a build up of crud in the keyless works, no lubrication and usually always neglect of the mainspring and associated components.
I agree entirely.
J
    • I am pretty sure the correct practice to insert a tensioned crystal is to use a crystal press - although I always hate doing it as one slip and the crystal can skid across your dial, this happened to me on a Tissot, mangled all the hands and scratched the dial down to bare metal. I much prefer to remove the bezel and install the crystal into the bezel and then the bezel back onto the watch, not sure if this is an option for you?
    • Well, Geiger counter showed up today and the dial and/or hands were extremely radioactive, reading quickly spiked from a baseline of 10-20 cpm to 100 and was still rising when I removed it. Trashed the whole thing. Thankfully nothing else outside the components was registering - work surface, tools, the paper I had used to clean off some components....    And now I have a Geiger counter to use to  check practice watches BEFORE disassembly
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
