Summer project.
I love mechanical things, not least the watches, clocks and other mechanical hardware. To be able to repair watches have been a wish in a really long time. Unfortunately I have not had a real place to practice and must recognize that doing it in the kitchen just cannot be reconciled with the family.
That is why I am now going to remodel our 70 's garage into a workshop and hobby room for joy for me and the rest of the family. It is anyway too small for a modern car.
The garage is at about 6.8 x 3 m. and there for approx. 20 square meters. The redevelopment will be extensive as i have to make heating and floor heating window and a small kitchenette. I am now almost finished clearing out the garage so that the work can begin. I will put up some pictures every now and then as the project progresses!
try to get a window facing the sun rise.  have fun.  vinn
Unfortunately it is not possible right now. In the first place, I get a window to the West, later perhaps a narrow one facing north! Over time maybe a towards the East!
No reports from me for a long time but next week my family is leaving for a week and i will be back in business. Lots of plans including finishing a 1972 München pin lever watch (new baalnce turned), servicing some watches (Vostok Komandirskie, Ricoh auto, HMT maybe...), some enameling experiments, making some tools (faceplate for mainplate and case turning) and.... designing my own brand :)
At the weekend i continued to work in the workshop. The load-bearing beams hase been attacked by boring beetles. If they are still active or not is hard to see, so I chose to smear with a means to be sure they are not coming back. 7.5 liters "PROTOX INSEKT" has come on with a brush. I have also created wind screen between the beams so that it does not blow into the insulation when it comes up. Today i started on the electrical installations in the ceiling, among other outlets for powering LED panels!
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
