Selecting a Tension Ring crystal
I need to get a new crystal for a watch I'm working on. It has a tension ring type glass. I've never bought this type before and have a couple of questions that someone may be able to help with.
How do i measure the glass. The case opening is 32.45mm what size would be appropriate.
There seems to be a couple of types on the Cousins site. Standard and Recessed. What does recessed actually mean? the glass the came out does have a recess where the ring sits, is that what it means?
Thanks for any help.
I'm curious as to what kind of watch it is .  Seiko has case to crystal lists .
Can you measure the old crystal diameter . A tension ring crystal will have a white or gold ring you specify when you order and be very slighter larger then the case opening .
I order from Tip Top Crystals quite a bit , and you can email Steve and ask questions .
If your watch case have  a recess where the crystal is you should have a recessed crystal. But i think you should have a ACT crystal with chrome or gold tension ring. This is the most common crystal.  32,45 i would go for a 32,6 or maybe a 32,5 but a 32,6 would be just about right i think?
The glass that came out is 32.50, but I can push it in by hand, so I think 32.60 would be the one. It's only an Avia, so I assume the standard glass will be right, as stated by Roger.
Since you need to order a crystal w/tension ring that is larger then the case measurement then you need to compress the edge of the crystal to get it to fit . Once the edges are in then you can seat it with a press . I usually use a press with my divers that have a crystal gasket to fit to .
Maybe others can give their methods and opinions .
As a matter of information. I bought a 32.5 and it was a perfect fit. I had to use the press to get it fully in. So it seems you don't want to go too big. Also, the crystal lift tool was no use at all, as you can't compress the tension ring. I guess that's the idea really.
Anyway, that was my experience, YMMV.
Way to go ..  You got it in without damage and it stays in . Can't ask for more then that .
  • 5 months later...
Rather than starting a new thread, can I ask about this crystal. There are so many to choose from, I'm not sure where to start. It seems the one I have the chrome ring actually holds the dial in place ie, if I put the dial in the case with out the crystal on, there is nothing stopping it falling out the front of the case.
The watch is a Tissot seastar
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
    • Sorry to jump in here, but I didn't want to start a new thread when there's already one regarding the second hand watch market. Can anyone tell me what I should be looking at when buying watches from eBay? I see loads on there for quite cheap, but after reading this thread I'm guessing they're all garbage and not worth the time? I recently bought an old Elco watch for 99p, just to practice on. I'm also really fond of the look of Services watches and Smiths Empire watches. I keep seeing them listed for around 5 or 6 pounds. Are they not worth the time buying? I'm not looking to sell watches to make a profit. I just want to buy watches I like the look of and wear them, but I also don't want to buy things that are going to be impossible to find parts for, or that have already been abused by someone else and broken beyond repair. Any tips?
    • I tried the Moebius 9415 from any sensible amount, down to microscopic a drop (or "super minimalistic"); the size of droplet which makes you really wonder why one would/should apply anything at all? But to no avail, consistently a lower amplitude compared to my Dr.Tillwich 1-3. Of course, as John mentioned above, the Dr.Tillwich 1-3, just like the Moebius 9010, likes to go somewhere else. Since short however, I'm the (proud?) owner of a bottle of Moebius Fixodrop. Can't say that I'm a proud owner of the 9415. So far, I haven't seen or discovered the "magic" of the 9415. Meanwhile, Moebius 🤣 has my money though.........
    • I used to be quite active on The Lotus Forum when I owned my Esprit. I was there for so long, Bibs asked me to be a moderator. I'm not sure how long I did that for, but I think I turned into the second longest serving moderator. When I 'handed back my keys', Bibs made me a Full Forum Member. Normally this is a paid membership. My reward I suppose for helping out for many years. Bibs (forum owner) is quite active on there and if I am not wrong, don't quote me in other words, I think he once said that the money from memberships didn't cover the running cost. He adds money himself to keep it going. Does Mark have any sort of subscription scheme on here? I'll admit that I never paid to be a member on TLF. I should have. I never did. I agree that it would be a good idea that there is some sort of contingency plan for this forum. I intend on becoming more active on here. Life has just been getting in the way recently. I enrolled on Mark's watch course and was keenly doing that, but even that has had to take a back seat for a while. I am looking forward to getting back into that and also starting to do work on the clocks that I have been amassing. To do that successfully, I see myself needing to lean on the other members here. If for whatever reason this forum was to close, I think a great many of us would struggle.
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
