Can anyone give me any pointers on removing this movement from the case? I thought it was a breakaway stem but I don't think it is now?
thank you
Can a moderator move this to the Watch Repair forum, please? I'm sorry I posted them to the incorrect forum. Thank you, Gary
I'm confused.. in the piciture I see the mov.t removed from case, and the case upside down with the dial reversed inside.
The movement is still in the back. The dial is in the top/front of the case.
I have come back to this watch as I need a project for the weekend. Anyone have any ideas on how to remove this movement form the case? I have flipped the movement ove and removed the dial but long term I need to get it out and back in!
any direction or suggestions would be very much appreciated!
thank you in advance!
 Gary
That is a strange one? Two piece stem? Looks like the setting lever has a screw? So it can't be lift to remove ? Maybe the movement is only a tight fit in the holder? What does it say on the movement? Any numbers or name?
Looks like a normal straight forward removal to me.  This lever is held with the screw I have circled which can be loosened from the movement side which allows you to remove the stem. A bit confused with the pics
5942b86351361_ScreenShot2017-06-15at17_37_33.png.54d25bb89087c81d4e1fa4c85b4b73c1.png
Gary has already stated that the movement is still in situ in the case back, therefore there is no access to the stem release screw.
The photo is not particularly clear but from what I can see it has to be a split stem. The stem is held in the movement by the set lever which appears to be a standard design as CB has suggested. It would be impossible to tighten the set lever screw with the movement in the case back, therefore the inner part of the stem must be in place before the the movement is installed and the outer part of the stem has to be installed after installation.
I would be inclined to dismantle the keyless works as far as possible to clear the decks and see if it is possible to get a clearer view of the stem where it goes through the case.
Hi E veryone,
I will try to take better photos this evening. Marc is correct. the movement is flipped in the case still in there. The dial was loose and I was able to remove it so we are seeing it in the case just flipped. I tried pulling the stem as I have a Wittnauer that has a split stem but it didn't give. I will try it again or take photos and post.
Thank you for assisting me with this one. I need to work on it this weekend! Will post more photos tonight.
Gary
Tried to take better photos and tried pulling hard in case it was a break away. No luck
! Seems I will have to resize my images. Bear with me!
Edited by Gary
Addendum
I don't understand why you can not access the other side. Some watches the crystal is set in it's own ring which also opens like a snap on case back. I presume this how you have got this far. The back will also open either via a snap back or screw action.
Front like this
59440ddf48ef3_ScreenShot2017-06-16at17_56_06.png.e6476ec8606e31ecb972f292eb1ad444.png
The is what I would consider the case back. all one piece. I will upload a better photo later but is all one piece.
Unconventional approach... have you tried holding the winding pinion still and unscrewing the crown?
If you do this then push the stem in you may have enough freedom to remove from the case
@Gary are you saying that what is preventing you from removing the movement from the case back is that you can't figure out how to remove the stem?
Must be a way to remove that movement.  Are you sure that it's not two parts? Seen movement rings that gets suck in the caseback a few times.
Gary, the case construction is the same  as a Roamer watch that I service a couple of years ago.  It will be a split stem that has to be separated to remove the movement.  These can be very stiff to separate with a straight pull and leverage may be required.  This was the case with the Roamer.
You might be able to turn the stem to a position that will allow the stem parts to slide apart as you to gently prise the movement out.
two piece (split) defiantly requires leverage.  I use tweezers under the crown for the slight more leverage,  if the 2 pieces are rusted together - use penetrating oil and heat.  a well worn 2 piece stem comes apart too  easly.   vin
