Sicura D500 Jump Watch
Hi, I'm new on here. Have just won a Sicura D500 Jump Watch on ebay. It looks battered from the pictures (yet to arrive) but it is working. I still have my 1973 Sicura, from when I was 11. The hands had fallen off and the mechanism stuck and so I left it for years. My original plan is to use the best case and crystal, take the face from my original and attach it to the working mechanism, and use the new red and white hands. But then I realised that I had never taken the back of the original watch off, so the hands must be inside the case, maybe jamming the mechanism.
So I gave it to a friend who's really looking forward to getting his hands on the watch and learning what makes it tick (apologies for the unintentional pun) but when he unscrewed the back he wasn't sure how to remove the mechanism from the case. He said to me something along the lines that he was looking for a release plate, but couldn't find it, so wondered if it was a block and something, and he didn't want to pull at it, in case it was the wrong thing to do!
Does anyone have any ideas on how to release the mechanism from the case? Many thanks.
Also I'd be grateful for any other tips on polishing out the glass and case. Enclosed is a photo of my original watch.
Probably a BFG866 movement. there is a small screw near the stem. Loosening that about two turn and realese  the stem and crown. The movement holder is just loose . It's the small tabs that stick out on the side. Just pull straight up.
Edited by rogart63
On 4/19/2017 at 1:14 AM, npharrison said:
The hands had fallen off and the mechanism stuck and so I left it for years.... But then I realised that I had never taken the back of the original watch off, so the hands must be inside the case, maybe jamming the mechanism.
There is only one hand - the second one.
You need to post pictures of the mov.t for questions related to it.
You can find many threads on buffing and polishing using the search box on the top right. BTW, your watch has a lapped "sunburst" finishing, which can't be really be done manually.
Edited by jdm
JDM - I called the red and white Pointer "hands" because I didn't know I could use the word "hand". Coloured red and white, 2 colours, I thought it might be plural :-)
Thanks for the nod for buffing and polishing. Everyone has been so helpful with their advice. My friend is hopefully looking at the watches this weekend so I'll have some idea of the state of play when I see him, and can work out what to do with them.
I'm refurbishing the original box inlay, having ordered some blue sticky back velour. I'm blowed if I can remember what the original strap was. I have a memory of a red and something coloured canvas strap for a watch, but not sure which one. I know I moved it on to a wide leather strap, with 2 fastenings to hold the watch in the middle of the strap, like a wide wristband, but given the box and inlay, that wasn't original. Don't think I had a metal strap, but a lot of photos show those with the watch.
I'm really enjoying this, as I'd never thought to refurbish a watch till I looked through a tin of childhood memories and got to thinking about my watch and what could be done with it.
  • Similar Content
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
