They look OK to me Micky.  The hands project a line that splits the 6 perfectly.  The 12 may be position slightly off on the dial, but very hard to tell fro a photo alone.
They are bang on with each hour, but my customer isn't happy, insisting they are misaligned, spent two days trying to please him, but don't know what else to do.
Ask him where he would like them and fit them to his specifications.  By the way is the watch the real deal or a copy?
Looks alright to me.  How does it look if you set the time at 6 a clock. Are they inline then?  Have experienced some slack in the hour wheel on some movements . Making the hand get in different positions if you turn the hands backwards or forwards. But never heard anyone complain about it.
At six o'clock its bang on too.  Using the dial printing as a horizontal rule, with the hands set at six o'clock, I have four perfect right angles (45 degrees reference points).
Agree with the slack on some movements, this movement is an Asian 7750 and it does indeed have quite a bit of play.
Some people with these reps have far more unreal expectations of them than any of my genuine watch brand customers.
Maybe he should go to a optician instead :)
I've actually never had a customer complain about the precision of my hand setting, and that's not to suggest mine has always been perfect. In my experience customers are usually extremely ignorant of the hand setting accuracy, they bring watches in that are off a solid 15 minutes and don't notice until I tell them. Pretty typical you'd get someone so picky on a replica though. Tough situation. I second about the dial printing, I also think that many genuine watches of various brands dont print their dials in a way that allows the hands to show truly perfectly at every position. He surely expects too much.
Maybe if he wants any better--He should fork out for the gen watch, where the perception of expenditure will re-align his eyeballs!!
Alignment looks pretty spot-on to me however!
I have to agree with everyone else.  They look good to me.  Panerai hands can be kind of tough because there aren't a lot of reference markers.  Add the fact that production accuracy (of the dial or movement) may not be a high priority and you have a perfect storm.
It may not be a good business practice, but If if were me and the customer is that picky I would send the watch back free of charge and not accept anymore work from them.  You just can't please some people and it sounds like you have bent over backwards trying to do so.
I will have to let this customer go.  I so prefer to work on genuine brand watches as my day job, but you'd be surprised of some flaws I have found with these too, the latest, a Tutima, the inner chapter ring was misaligned.
Aye, and that would be your fault too! ;)
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
