Hi all,
After 2 months, just received a watch back from Tag service UK. Sent in for a new battery but was told after it'd been inspected that it needed a full quartz movement overhaul. This included a 'Case and bracelet cleaning in ultrasonic vibration'. Full details - http://customer-service.tagheuer.com/en-gb/service/complete-quartz-overhaul-0
Whilst its an older model and had some case/glass scratching from wear and tear when I sent it off, unfortunately it's been returned and now the black bezel (think this is the right term) now has what looks like 'pitting' or something all over - one quarter looks really bad. Basically the black finish looks like its been partially removed. Quite shocked that it was just returned in this condition without any advance warning. Looks a right mess. Also, if the cleaning has caused this, I was not given any indication of there being any risk that it could have this affect.
They have asked me to return it, which I will, but I'd be interested to hear views on this i.e. could the ultrasonic cleaning have caused this or something else?
Thoughts? Thanks.....
Could have been the ultrasonic cleaning, almost looks like someone took some solvent to it! They certainly owe you a new bezel insert.
Good luck!
agree with dadistic, it is a shame how it was returned to you like this. I hope you made some photos before you send it to Tag. A normal battery swap would have cost around 20 dollar max at a local watchmaker, a full service at Tag is a different story, who can garantee the full service was necessary....Due to some experiences I lost my faith in these inspections as 9 out of 10 they come out advicing a full service.....
Good luck!
Thanks!
It's given good service for many years, so I thought I'd treat it to a full overhaul after talking to TAG. It went for a battery but after inspection they told me there was excessive battery drain so they recommended the full overhaul. No mention at the time that them cleaning it as part of the overhaul could damage it (if this indeed was the cause). Now wished I hadn't bothered!
Really surprised that they sent it back like that, usually I'd remove the bracelet to be cleaned in the ultrasonic tank and clean around the bezel with some swabs, mild cleaning solvent and some brushing. I know that the bezels (have done it on my Tag before) can be removed but I think this proves an unnecessary risk to the bezel clip/spring when just for cleaning purposes as parts aren't readily available or cost a fortune!
I'd definitely write to Tag demanding a new bezel, I'm sure they've got a fair few lying about...
Regards,
Chris
To me, it is beyond belief that Tag would ever send a watch back in this condition.  That they would even damage a watch like this is unfathomable.  I could see this from a novice watchmaker with little or no experience in watch cleaning procedures, but wasn't this a professional Tag service center?  Shameful...
Ultrasonic cleaning for sure. THEY will have to replace the bezel or bezel insert. Another very poor service indeed.
My nephew put his Rotary in for a battery
change. Unfortunately who ever did the change did not appreciate it had a screw down crown & stripped the thread of the crown. Lucky for him uncle Del fixed it.
Regards,
Chris
Thanks Chris. I'll be in touch next time the battery needs replacing! To be fair, when I phoned TAG I just got the call handler and they just asked for it to be returned. I'll see what they say once they've looked at it.
I was just trying to get a sense of whether the cleaning could have caused this and whether the bezel/case/bracelet would routinely go into whatever is involved in ultrasonic cleaning.
Regards Jon
Thanks. That was my gut feeling tho I've no idea what the cleaning actually involves or if the bezel would routinely be included (as well as the bracelet/case) and if so, whether anyone else has experienced this.
Putting plastic/nylon parts in watch cleaning machines or ultra sonic machines is not recommended. The solvents can often cause issues such as what has happened to the bezel. The issue you might have is proving it was OK before the service.
I find this all very strange and find it hard to believe that an official TAG repair lab caused the damage.  Surely if anyone knows how a TAG case should be cleaned it would be them.
It's not the first time that I hear about official service centers to do unnecessary service and/or damage to watches.
In this case I suspect carelessly left the bezel face down an high power U/S cleaner and caused abrasion damage. These business are staffed by employees that do not have to repond personally for what they do, unlike an indipendent watchmaker. One would have to go through the hassle of taking pictures of watch and send these together with it. Sounds obsessive but that's how it is.
Unbelievable. Hard to tell from the photos weather it's abrasive damage or the bezel insert finish has shattered under the cleaning process. Even before and after photos would have little legal relevance unless they were taken in front of a creditable independent witness at the time of sending the watch off for service.
Problem with taking a watch to an independent watchmaker is knowing one. Most jewellers these days, once seeing an expensive brand name, will just simply send you away.
If that's the service you received it is shameful
Sent from my SM-T585 using Tapatalk
Now there is a nice uncle....I am sure your nephew is happy, Del.:thumbsu:
The sad thing is that these are the outfits that the likes of Swatch group et al insist know best what they are doing and are seeking to ensure that all their watches go to by closing off the supply of parts to independents.
Absolutely agree, hence our shock on receiving it back like this. I originally posted as I just do not understand how this could have happened or what processes they use that may have caused this.
Clearly problems can occur and they have asked for the watch back so let's see what they say.
I totally agree with this.
Most photos are digital these days and the imbedded Exif file (Extended Image Format) hold all the information relating to the image including when and where  it was taken.
Wow what a terrible job. It's as if they sent it hoping that you wouldn't notice... Please keep us up to date as to how it all moves along.
What I was saying was to send printed pictures with the watch. No doubts about when have been taken, and a clear signal given.
I'm aware of data recorded images and how easy it is to alter that data. My company work in collation of such evidential processes where very strict protocols and procedures have to be followed. Any breaches of such, regardless of the quality of the image, will normally be thrown out of court.
The above said. I'm still hopeful for the OP that the Service Centre will, if for no other reason, will rectify the problem, to preserve their reputation. But if they're dodgy enough to send a damaged watch back to the customer i have concerns.
As for "Swatch" and if you're looking for quality expensive watch, buy Japanese or similar. Leave Swatch products alone.
If you buy for investment and looking Swiss the pre-ceramic Rolex submariner or daytona are holding their prices well and you're more likely to recover your money on resale.
Sent from my SM-G920F using Tapatalk
"Swatch"???
My reference was to anyone considering purchase.
1. Any eta Base movement now being restricted by Swatch.
2. Purchase as investment. Everyone knows Rolex. Most of Joe public wouldn't even know Tag or Omega?
My reference wasn't direct to Tag as a brand I don't particularly like them and have no interest in them.
I adore Omega but as investment would always opt Rolex
Alright, but aren't talking about law here. Not all cases go to course, and if they do, it is small claims. Just a simple practical precaution. Which service manager would have the face to claim that damage was pre-existing when pictures had accompanied the watch?
45 minutes ago, digginstony said:
My reference was to anyone considering a purchase.
I just wondered Tony, as it didn't seem to be relevant to the original post.
