I'll pop into the 2 or 3 near me. If nit, trip into town centre.
I avoid ordering on Amazon as there are too many dodgy vendors to know who is selling legit cells.
Update:
Bought a new Silver Oxide battery and fitted it. Nothing happened so I started adjusting the time advancing the hands 48 hours, nothing.
Then I tried pulling the crown fully out and pushing it back multiple times.
EUREKA! it started ticking and hasn't stopped since.
Thanks to ALL the advice given :D
Now to tighten up the loose links in the bracelet.
well done, don't forget even a quartz watch has jewels that need oiling, sometimes they dry out & can stick so need an oil. but more likely a bit of debris in it somewhere.
Nice! I usually and "inadvertently" drop them but I suppose I'll be adopting this method from now on....mmm, Learning from others' experience! :)
Excellent work!
Links on bracelet all nipped up. As good as new except for where the colour has slightly worn away. Can't wait to return it to her.
Well done mate. I am sure she will love it :)
  • 2 years later...
UPDATE
Took the movement out to put case and bracelet in ultrasonic.
Once I was ready to refit, noticed the stem wouldnt stay in.
Took a macro pic and saw a piece sticking out beyond the circuit board. Should it?
Maybe I need to replace movement. How much for a new ETA V8 quartz?
1 hour ago, ro63rto said:
The arrow points to the dimpled stem release button but whay does the plus sign mean and what is the screw for on the opposite end?
Means positive voltage and the screw likely holds the circuit board in place.
Ok. Just seemed a bit odd that the release button was being pointed out by a plus sign.
Thought maybe the screw was to release the button as it now won't pop back up.
Probably old oil is keeping it down. I barely pressed it to release stem.
did you know that an accutron will run with the battery reversed?   i bought one that  way.  it had been running for months.    the quartz watch may not,BUT  i  don't think reversal of current could damage it.?   vinn
Googling reveals that the ETA 956.114 Has been discontinued replaced with the 956.112 Then I've attached a technical sheet with all the specifications repair etc. should answer a few questions.
Then using a wrong battery usually isn't going to be an issue but it makes a great excuse if the watch doesn't work. Quartz watches have similar problems that mechanical watches have like lubrication dries out. They're considerably more sensitive to foreign matter floating around they don't have the energy of a mainspring powered watch. Then if you can drop the watch or hit it with enough force it's possible to break the quartz crystal than the watch is totally dead. Plus unskilled battery changers have a habit of scratching the coil which breaks the wire.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&ETA-ESA_956_114
613_ETA956.032,956.042,956.102,956.112,956.122,956.402,956.412.pdf
Thanks John but the second link to the pdf doesn't seem to work. It looks like its been lumped into one long string in tapatalk.
Long past the worry about the battery.
Just the setting lever button not coming back up.
Downloaded the service sheet from Gleaves so will attempt a mini stripdown tomorrow.
Over the years if Ive found a battery leak, its invariably been a Renata battery! A search on the web about watch-battery leaks tends to confirm that Renata do tend to leak,--Not good for an expensive movement or a rare coil....
I use only Sony or Maxell myself or at a push, Rayovac, none of which Ive ever seen have a leak--Perhaps though, You know different!...
One thing is certain--Cheapo pound-shop Alkaline batteries have no place in a watch, Reminds me of a seller on ebay with a nice Omega Seamaster with ESA 9162 tuning-fork, complete with an AG-10 pound-shop special--I Didnt bid on it!
Edited by Alastair
An Accutron tuning-fork Always has the positive terminal (main case of battery) Downwards in the movement--giving the impression its wrong way round, they certainly Wont run with the batt reversed--In fact a reversed batt can do damage to the 0.22uF Tantalum cap in the circuit, if its left in the wrong way for some time, a PITA to change on a 218x calibre- In fact, Most things are a PITA with a 218!...
Only the Accutron Spaceview that Citizen re-issued and made 1000 of as an Anniversary watch in 2010 has the batt in conventional orientation--with the pos uppermost......
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
