Hello from the Pocono mountains in PA.
Hi everyone,
              I've been collecting and restoring Seiko's for about 10 years now. I've also been accumulating tools and equipment to fully service their movements. I stumbled across this forum while doing research on Seiko lubricant's and decided it was a great knowledge base and decided to join up.
Regards,
Tom
3 hours ago, vinn3 said:
welcome to the forum.  if you would, tell us about the problems with that "push button" stem release mechanism,  as several members have had problems with it.  thanks, and again welcome.  vin
If you're referring to the stem release issue on the 6139's, 6138's, and others where the keyless works fall out of position after removing the stem, it's due to pressing the stem release button and removing the stem + crown while the crown is pulled to the time setting position (number 2 position) rather then the crown being in the number 1 position.
Often times you can coax the release button back into position by inserting the stem slightly in the direction of the button and giggling it gently until things line up. If you're unsuccessful then the dial, hands, day + date wheels must be removed to access the keyless works.
19 minutes ago, steve855 said:
Hi Tom! Good folks on here and lots of knowledge. There are some very good pros, and plenty of amatuers like me. You'll notice some familiar faces here I'm sure.
Steve
from Berks Co. PA
Sent from my GT-P5113 using Tapatalk
Hi Steve,
       Nice to see you over here! We still need to get together to share some case refinishing techniques.......:) Been busy all winter so far. Sorry for the delay.
Tom
Hi Steve,
Tom
No problem at all, been quite busy myself. Glad to see you here at WRT.
Steve
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
