I've come across this Ingersoll and am struggling.
It is in a backless case - the only access is via the front glass.  I have pulled the crown as hard as I am willing and this does not separate.
The watch winds, ticks and stops, so I'd like to get a look at the mechanism.  Can anyone help?
Also, the only Ingersolls I've come-across are Triumphs, this is not so marked.  Can anyone help with a model or age?
Thank you all!
I'm sure the back comes off with a good case knife and the movement drops out because the so call d stem is a different fitting to other pocket watches, I had to repair loads of these little blighters as an apprentice, I was serving my time back it the 70's but this style goes way way back I think to the early 50's, yours is a later model as its got s/s
Smiths did them as well.
Edited by oldhippy
Hi again Oldhippy, thanks for the response!
I'm sorry but, if there is a rear-opening, I cannot see it and it is a far better fit than the front-opening?  I have tried to capture the issue on camera but it's not easy on a bright, shiny surface.
I'll say what I would do if there was no Internet to search and ask :)
Remove hands, (twist ?) and lift the dial, then the stem release will be accessible.
It's always the simple answers that elude me!  Thank you, I'll give that a go.
Tried the google option but, as always, the answers can be gotten but only if you can word the question properly!
Hi again!
Yes, that accesses the face area but there's still no "back-door access" (fnar-fnar).  I'll try the hands bit later as there's no other obvious stem release or mechanism access.
If it's a "negative set" movement then there will be no stem release as such since the stem will be captive in the case.
The only thing I can say is this one must be a newer type to what I repaired years ago, because the backs were so easy to flip off with a case knife.
I'd possibly also try tapping it onto the desk in case the movement starts to hinge outwards (coming out at "6" due to hinging near the stem at "12"). Just a guess.
I have a T Eaton pocket watch with a high polish case and the back screws off. When screwed on the joint is almost invisible. Sterling silver case mind.
I am sure that possibility has been explored...
Ron
Thank you for the new option - I have never seen what you describe and am interested in investigating.
With the front removed the mechanism is very free in the case and can be encouraged forwards as you describe.  However, after a couple of mm it does come to a definite stop, suggesting either a stiff hinge, or no hinge.  How much pressure would I have to apply if there were a hinge?
Ron
Like Rodabod's answer, this one intrigues me too.  I haven't tried unscrewing the back and I am skeptical that the join on this particular case could be that invisible.
I am at work now but will certainly give both answers a good try!
The ONLY reason I've not yet popped the hands off to release the face yet is that my (slightly-arthritic) meat-hooks have such trouble getting the beggars back on.  Is there a specific tool that'd make this easier?
Yes there are tools to help but manually removing and setting hands is a skill which you must acquire otherwise you can't work with watches, what about practicing? Keep the watch close, use good magnification, lay the elbows on the bench and try to be relaxed.
I have some scrappers, I should get down to it I know.  Failure is frustrating but it's practice I need.
Back does not unscrew.
15 minutes ago, rodabod said:
Can you scroll down to the section on "setting" on this page and try to figure out if yours is "negative set"? You may be able to tell depending on how the time is set; do you push the crown in or pull it...
http://www.vintagewatchstraps.com/watchmovement.php
It is, if I'm reading right, a positive set: winding occurs with the crown in situ and the crown is pulled up/out to set the hands.
I have given a firm pull in order to check for a separating stem and I am confident that it does not.
On the bottom of the dial, just under the "6" position, is printed "Swiss 1922".  Now the watch isn't that old, I'm sure.  Does this relate to a model instead?
  • Similar Content
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
