Omega 1010, low amplitude
mikepilk
I've just finished cleaning an Omega 1010 and I'm only gettting about 230° amplitude.
This is the second 1010 in my collection, and with the first one, I only got about the same amplitude.
For lubrication I used :
9010 on the balance,escape wheel and fourth wheel,
9415 on the pallet jewels,
D5 on the rest of the gear train (including the centre second pinion).
The spring looks good. All the jewels and pivots looked OK under a x10 Loupe.
Is anyone familiar with this movement and know what I've done wrong or what I should be looking for ?
I plan to have a  look at the jewels/pivots under the microscope - should have done it initially !
Well the most obvious culprit would would be a played out mainspring, otherwise it sounds like you're looking in the right places.  I'm not sure if you have already but you might want to let it run for a bit- I usually give it twenty-four hours after assembly to let the oil settle/distribute before looking for an accurate reading on amplitude.  Then I'd check the following:
  1. Cleaned and properly lubricated jewels & bushings
  2. Bent or lopsided pivots
  3. Worn bushings, broken or cracked jewel settings
  4. End shake on all wheels
With Incabloc protection you'll also want to make sure the top and bottom cap jewels on the balance haven't been swapped- they aren't always the same thickness.
Edited by RyMoeller
Spelling
D5 is kinda thick, not to mention is natural oil with a shorter life, synthetic would be better. I would use 9010 on everything that moves from the mainspring. That made a difference for me. Anyway, even 230' is plenty for the mov.t to run strong and accurate. And you also have to look at the overall pattern.
Edited by jdm
Over-oiling the pallets can reduce amplitude. I presume by spoiling the impulse.
If you have a timegrapher, how was the amplitude in vertical positions such as pendant down and pendant left?
You can live with lower amplitude as long as the escapment is well poised. If it isn't, then you'll get progressively worse positional variation as the watch winds down which could become problematic.
6 hours ago, mikepilk said:
Can too much oil (it's not sloshing around!) have so much effect?
Yes, a liberal application of oil will have an effect on amplitude.  As @clockboy stated though, in my book 230 would be acceptable- especially if I felt I may have gone a little heavy on the oil.
Edited by RyMoeller
I can live with the 230 - the watch will only get the occasional outing.
I was more interested as to why.
I've spotted one problem. The auto mechanism isn't jewelled and one of the pivot holes is oval. I can see the pivot waggling round if I manually wind it.
Are the brass bearings machined in, or pressed in replaceable parts ?
Bearings on trainwheel bridges are often a culprit for low amp? At least on Seiko. Think the Omega 1010 is about the same construction with the bushing directly in the brass . Check for excessive movement in the barrel?
Edited by rogart63
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
