Hi folks,
I was wondering if anyone knows how to remove a watch face off an Emporio Armani AR-2432. I was able to remove the back case, stem, and push pins but to my shock and horror, found out that the watch face was bigger than the case so I can't pull it from the back.
The only thing I can think of is to pop open the front bezel by sticking a stanley knife or razor between the bezel and case. However, before I do that and wreck the watch, I thought it might be best to check with the pros.
Reason why I need to get to the front face is to re-position the two chronograph arms that's come loose and jangling around the crystal area.
I've attached pictures on how it looks and where I want to pop it open
If anyone can offer a tip or two please let me know.
Thank you in advance.
Jesse
House of George
Yes it looks like a removable front bezel. As you rightly say a razor blade ran around the edge to start it of then widen the gap with your stanley blade.
Just to give everyone an update, yes, the blade/knife did work.
I had to use the Stanley Knife as the razor blade was too flexible and flimsy. I did work around the bezel by turning the watch around as I work the knife between the bezel and case.
After a while, the gap widened and the whole bezel and crystal popped out. Woohoo!!
I was able to affix the sub-dial arms and place them on 12 positions. Unfortunately though, it seems the movement is faulty. I pressed the buttons and the sub-dials won't move at all and I doubt it measures time in minutes rather than in seconds.
It's not a big issue however as the customer just wants it put back in place. The loose arms floating around the watch face was very much annoying. Well, not anymore.
Thanks for everyone's input. <3
Jesse
Hiya,
Thanks for the suggestion but the customer is happy with just putting back the arms on the sub-dials and is not interested in getting the movement replaced.
Cheers.
Jesse
  • 1 year later...
Anyone have any other guidance here? I've been trying to separate the front bezel off and can't make any progress for the life of me...
If your watch is identical to the one in picture, the answer has been given above already.
If it's different, post good pictures front, back and side.
BTW, we've a section here used to introduce oneself even before asking pictures.
  • 7 months later...
Im having the same problem. Took the back off, took out the crown and found the face/dial is bigger than the opening at the back by 2.5 mm.
I need to change the crystal.
How does the bezel go back on? Is it pop on or does it require glue?
Picture of the watch with open back can be seen below.
Many thanks to any one that can shed some light on this.
The bezel has a small groove shown in the pictures at the top of this post, using a small knife/razor you can pop the bezel off. It snaps back in with a press.
Thanks fella,
I managed to do this yesterday. It takes a while! Notch on mine was at the 6 o clock position.
There does not seem to be much info about this kind of watch on the net or YouTube so hopefully this thread can help others as this is a very popular watch. Many in the Armani range are made in the same way.
A Stanley knife type blade in a good quality holder helps. I started at the notch and went around the bezel a few times. Need to be careful not to aim the pressure in wards when popping off the bezel (It pops very suddenly and shoots off) I managed to damage the hour hand and the chronograph hand fell out. ( My first time fixing a watch so still learning ) bent the hour hand back in to place so it was all good.
There is a seal where the bezel fits in to the case and I would have thought running a blade to pop it off would damage this seal. Worth replacing if you plan on going swimming while wearing this watch.
As Kevin says above, It pops back on. Took me a while because it wouldn’t fit flush. I turned the bezel 180 degrees and it went straight on, so worth trying different directions / positions.
You defiantly need the following...  A watch press - Watch repair kit - !Very steady and nimble hands!
Image below shows the watch taken apart.
  • Similar Content
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
