Whilst looking on the net I came across an unusual vintage Rolex, the top half of the dial has Roman numerals while the lower half has Arabic !  with a seconds subdial at 9 o'clock,
wonder if anyone knows of this watch ?
I have a picture but not sure if it contravenes copyright if I post it ?
Don't know. How ever my favourite is explorer. Its features are amazing. The Explorer’s Oyster case, guaranteed waterproof to a depth of 100 metres (330 feet), is a paragon of robustness. Its characteristically shaped middle case is crafted from a solid block of particularly corrosion-resistant 904L steel. The fluted case back is hermetically screwed down with a special tool that allows only Rolex watchmakers to access the movement. Fitted with the Twinlock double waterproofness system, the winding crown screws down securely against the case. The crystal is made of virtually scratchproof sapphire. The waterproof Oyster case provides optimum protection for the Explorer’s high-precision movement. I have some good work experience with a OOH ERP and my words are clearly based on what I felt through such processes in the past.
This style of dial is know as a "California" dial and a number of manufacturers have used it at times.
There are various stories regarding both the origin of this style and the name, 5 minutes googlefoo turns up lots of info and pics.
The sub dial at 9 suggests that it has a pocket watch movement in a wrist watch case, I believe that Rolex did make an Oyster pocket watch which may have played a part in the evolution of their first dive watch.
It's a pocket watch conversion so the dial is a redial and not original it may or may not have a Rolex calibre based on a cortebert ebauche. As a watch its as bogus as a bogus thing from the planet Bogus. Straight out of Poland or Bulgaria these things are usually advertised as of military origin. I think the only Rolex produced military watches with this kind of dial would be a Panerai produced for the italian navy.
It doesn't look like a real Rolex but I like the "vintage" style of the lume (nice aging color, hands and dial) and the general appearance trying to convey some Rolex-ish presence. Other than that, I don't think anyone will take it seriously as a Rolex, not being their style. Again, I might be wrong and if so, it might command a respectable amount of money for being one of a kind...I guess!
On the other hand, I wouldn't be surprised to find inside a Chinese 6497 clone! :)
Cheers,
Bob
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
