I was just going through a used bookstore this afternoon after I got off work and came across this. Decided to take it home!9c0278fe5fddfb09e1c61086905cdc3f.jpg
Nice find.
Its really hard to find good technical books at second hand book stores where I live, but when I was in the UK in July I found several on a day trip to York which I was thrilled with.
I've got that book on my shelf but haven't read it yet, but suspect I will get more into it over the next few months as my night course is starting to move back into watches from clocks.
I really like this book. And calling it a 'bible' of repair is actually quite apt, as there are ...14 -- if i remember correctly -- 'commandments' of professional watch repairer ethics, which should be located somewhere at the back of the book. (my copy looks different to that)
Edited by Ishima
good show,  i re- read it often.  as far as i know,  theres only  one edition.   it is a very good training manual AND  it should be read "cover to cover"  UNLESS -- you are only interested non- vintage watches (including  pocket watches).  OR  flipping watches.  vinn
A standard book on the topic - every repairer and tinkerer and lover of horology should read it. It's certainly not hard to find a s/h copy and, if I remember correctly, I have it on my Kindle as well.
  • 4 weeks later...
Got this old version which I found in a watchmakers heritage I bought some years ago. As the pages were very fragile I scanned it to read it on my mac. Second revised version with wonderfull drawings....
On 10/21/2016 at 2:51 PM, parmenion31 said:
Hmm i was right , that book looked familiar to me , because i own allready a copy haha.
Looks like an "easy" read...:startle: if you can read Greek...I am a bit rusty...
Edited by MilTimeCan
in the index,  note there is no definition of  "caliber".    also in the main spring pages,  Movato has a patent on a winding clutch.  i would like to know if any other watches used this clutch.  vinn
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
