Stupid day
Tried to correct shape on an hairsping, It wasn't even much wrong. Failed miserably with the typical (for me) sequence of any corrections making it worse. Now is junk.
Grabbed a brand new balance complete, End stud has to be inserted on the balance cock (ETACHRHON, not screw type). Did not follow Seiko instructions to do that with the balance mounted, slip push and pull, another one is distorted and goes  to the trash bin.
Tapatalk on my "new" smartphone doesn't connect.
Stupid day.
I think we all have those days jdm don't get too upset. I was servicing my father's watch a couple of weeks ago. It took me a good nine hours and when I was done the clutch wheel didn't want to engage to wind the watch! I ended up taking it all apart again and in the process lost a small spring that flew across the room and I just gave up. It really got to me and lowered my confidence, but I realized that everyone makes mistakes how else can we learn?
It took a lot of time and concentration to drill both end of the balance of the Agat stop watch. And ruined all with a replacement pivot having to big cone angle.... I make this mistake a second time :pulling-hair-out:
Put this project aside for a while.
Edited by szbalogh
I did a strip down of a really nice Seiko 2206a movement last night.  Everything went swimmingly.  I put the balance cock on a balance tack for safe keeping before reinstalling it after strip down.  One errant movement sent the balance cock off the tack and across the desk.  Literally, it flew like a click spring from my tweezers.  (sigh)  That's when you know it's time to pack it in (and maybe have a drink).  Luckily it appears the cock, balance, and hairspring survived.  It'll be amazing if that's the case.  We'll see.
We all have days like this I'm sure.  I have two containers with cursed movements in them.  Nothing I do can go right with those two.  I've turned a hairspring into a tiny little rat's nest too.  It's amazing what skilled hands can do with so little effort!
I hope things go better for you later.  Usually bad days are followed shortly by those amazing days where everything goes right and you think, "this isn't that hard".  ^_^
Thanks guys. My issue with myself is that I've already made small pile of destroyed HS. Even if Seiko parts are not expensive, it's such a waste. Admittedly today wasn't my better manual ability day and I should have gave up since the beginning.
There are reasons why I work on mostly pocket watches, the larger the better. The parts are much bigger and a bit easier to work with. The added plus is, I really like pocket watches. However I frequently loose or break things, It gives me an opportunity to use as much bad language as I can.
Im OCD with my watches and I have screwed up quite a few when I really shouldn't have touched them. Don't get too down about it. At the end of the day they are just objects anyway. And they can be repaired.
Absolutely, no big deal. But I need my watches to work well in order to sell them. This one had a poor amplitude to begin with, so money/time investment was in the budget already.
Last couple of days I have been trying to learn to use a mainspring winder.  First two attempts ended up coming out into nice tight tangled balls!
On a positive note......I think they may make nice Christmas tree decorations!
Eric
I've had similar repair slowness due to parts retrieval, this Seiko 8306 has more springs that 1950's mattress! I have pinged a few around but luckily found and got back in...Installed a new day wheel and it still won't advance, so off with the top end again, checked all setting and winding functions, still good, but man what a time with this one... thought I had date jumper spring in backwards.:huh: Then the ^%$# crown came off! :pulling-hair-out:
 My luck, it's my watch and not a friends. My empathies gentleman....DSCF0321.JPG
I've done that! Mine did not survive intact. Out of flat now. I think I can fix it, but am waiting for a nice relaxed day :)
Well unfortunately the same happened to me- hairspring looks like a whirling dervish.  Thankfully Seiko parts are not expensive!
    • Does it say 17 jewels on the dial or on the movement ?
    • Hello and welcome from Leeds.
    • Lots of rust on that hairspring Nev, would you even try to clean it up ?
    • How do you find the working distance from microscope lens to movement? Is it comfortable enough to get tools in?
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
