Timex disassembly help
On a local watchmaker forum one is asking help to disassemble this Timex with m10x movement.
The autowinder is already removed. The stem can be pulled out after undo that screw next to it. The glass is not in a removable bezel. Please help, how can we remove the movement?
The watch is going a few ticks and then stops. The balance is wobbling so there is a screw on the dial side to decrease endshake. We want to get to that screw.
Thank You!
They're not designed to be serviced. I think the accepted method of 'servicing' is to remove the dial and hands and dunk the movement in cleaning fluid followed by oiling the pivots.
Looks like Timex was ahead of its time, the new swatch auto is similar but I don't think it'll outlast a Timex!
Anil
Having only yesterday serviced a 1975 Cal.32 Timex auto in accordance with Timex's published procedures, including adjusting the rotor bearings by tightening the rivet on my staking set, I can happily report an increase in amplitude of about 100 degrees to just under 200 degrees (it was desperately in need of a clean), and a rate of +/-20sec per day. Not the performance I would expect to see from a fully jewelled Swiss watch, but not too bad at all for a 40 year old pin pallet, 0 jewel budget watch that is still on its original main spring.
Not only were Timex pin pallet movements most definitely meant to be serviced, but the process is both quick and easy, and the results worth while.
:thumbsu:
1 hour ago, bobm12 said:
Walkthrough, Marc? :D
Sadly Bob on this one the camera was not on the bench.
To be fair though the process is so simple that there isn't really anything to see. That being said, the next Timex I do I will present for your delectation.
Thank you Marc. Much appreciated! I'll be curious to see the next one. Never done a Timex myself!
Pity you didn't have the camera this time, though! Interesting how those rivets are worked out!
Cheers,
Bob
  • 3 years later...
On 10/6/2016 at 3:22 PM, oldhippy said:
Years ago I would disassemble Timex watches with a hammer because there **BLEEP** rubbish.
On 10/6/2016 at 3:58 PM, Cad101 said:
I have yet to find a timex watch you can actually service all those riveted plates make it impossible.
One has to try
On 10/6/2016 at 6:32 PM, szbalogh said:
I have found a topic here showing the stripped down movement :) But lacking in the disassembly of the watch.
Meanwhile the guy could adjust the balance with that screw and now it keeps moving but with terrible low amplitude.
That's what I am going to do clean the movement
Anil
I am going to try and do that.
:thumbsu:
I agree.
Thank You!
   the inverted cone shape adjusting screw? I  think  the staff is supost to "float a bit".    vin
On 12/29/2019 at 4:22 PM, cadet said:
Hi, can you tell me how to get the movement out of a Timex which is vintage and assembled in Taiwan.
Just wanted to bring your attention to the feature that allows to group answers (in this case to a 3 years old topic) to multiple postings by clicking the plus sign on the bottom left corner of each, and then "Quote" in the pop-up that appears the bottom right.
    i am wearing a timex - as we speak !   that is a " space age timex"  -- never seen one of those.    that floating balance might require a different viscosity of lube oil ?    vin  p.s. --" the model 29 is a mod. 22 with a winder hung on it".   via timex collectors site.
Edited by vinn3
new info from web
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
