How to drop oil from moubius bottle
rogart63
Conveniently I can't find the box my Elgin oil came in to show a picture of what they had. So they had if I remember two separate lids the normal lid and another one that had a glass rod with a small ball on the end. So when you inserted into the bottle which was bigger than the moubius bottle you would get a small amount oil out. Using glass like this is nice as it's easy to clean and shouldn't contaminate the oil. Despite the advertisements from moubius at one time promoting their oil lasted forever now the recommendation is tossing the bottles every couple of years I suspect more because contamination in the bottle than actual breaking down. Then I've seen companies like Rolex put their lubricants in a syringe to avoid this problem.
I have asked other watchmakers they use the same method that I use. A very clean pair of tweezers usually like number five as they're small enough. Insert into the bottle when they're closed they will pick up a small droplet of oil. When you open them up slowly the droplet will fall off or run down the ends into the oil cups. They just make sure you clean your tweezers carefully afterwards.
  • Like 5
55 minutes ago, anilv said:
Hold the bottle over your oil-pot...tap the bottom of the moebius bottle with the back of a tweezer, a drop will...well...drop I suppose.
Not with 9010... it will be an instantaneous spill :blink:
Anil
That doesn't work on this bottle. The other i hade was a little bigger neck on .That worked great.  Without the tapping.
Take a plastic straw and cut out a strip that is abt half the size of the hole in the bottle and abt 40-50mm long - dip in the oil and then transfer the oil on the curved tip to your oil pot!
If you can find straws with a small enough diameter to fit inside the bottle - just cut to length, dip 1-5mm in the oil - cover the top of your "straw pipe" with your finger - move to oil pot and then remove your finger - viola.
    • You need to know at least the basics. Then the questions that You ask will begin to make sense. From what is seen on the video, the gear train and escapement look fine, but the balance doesn't rotate free. I can suppose that the thin gold colored shim that must stay under the balance cock is not in place.
    • Yes, there are a lot of shapes and all of them are used in different cases. The one in Waltham A11 is one of the most spreaded and is what I have shown in the beginning. Of course, the radius of the final curve will depend on the distance between the hole in the stone and the regulator pins on the cock
    • I just found these. They don't really grab my eye at the moment, but having seen the change in some of the watches on here, before & after, the results have been pretty impressive. https://www.ebay.com.au/itm/196382906131?itmmeta=01HXBSJJXDB5J6H916ARJP9PHE&hash=item2db9555713:g:REwAAOSwUNdmOYAZ&itmprp=enc%3AAQAJAAAAwOAlUO3a1pAUX60Y8gUeXMPriraj5e7rkBNH2EA6cIUH7kb7hzoq6jRmOsYOQazk9R%2FteDESr1e50Asabv2tbJyDM%2FVODtmrAScFS4jPhHdgu6Jvt%2BFuRGBijpTkPl4NiK%2FDGr6qztc1Ujb33Tt6YdaUztOH9R1y9XJbwjH0puPDy8m0ilYcal7Vphcp7d59DLtBliNnbqfxfWhxdia2xMRyHYFHzR0Rg7NqB1z4xQGMZb73MAG4QBiF9FMkrII88Q%3D%3D|tkp%3ABk9SR_KuyvnqYw
    • I agree, it's getting harder and harder to find anything that meets the brief other than complete junk, or fake/frankenwatches. I would be in favor of raising the limit so people can continue to enjoy the challenge of resurrecting these low cost watches to their former glory and allowing the watchmaker the ability of practicing new skills without the worry of breaking the bank if all doesn't go to plan. Now all we need to do is settle on a value - maybe base the value on a standard currency so we are all playing by the same rules ($, £, €...?) Unless anyone minds I could start a poll and we could all vote on currency and value... let me know!
    • Same for me, but this is the first time I use the Bestfit. I understand that, for a 17-3/4 caliber, I have to consult page 150, but I can't find any resemblance. Thank you for all your research. I learn a little more each time I use this forum 😀
