I can't seam to get the oil out of the bottle? The neck of the bottle is to small. This is the 9010 oil. I have been thinking of some kind of capillary tube. But glass seams so fragile?
Conveniently I can't find the box my Elgin oil came in to show a picture of what they had. So they had if I remember two separate lids the normal lid and another one that had a glass rod with a small ball on the end. So when you inserted into the bottle which was bigger than the moubius bottle you would get a small amount oil out. Using glass like this is nice as it's easy to clean and shouldn't contaminate the oil. Despite the advertisements from moubius at one time promoting their oil lasted forever now the recommendation is tossing the bottles every couple of years I suspect more because contamination in the bottle than actual breaking down. Then I've seen companies like Rolex put their lubricants in a syringe to avoid this problem.
I have asked other watchmakers they use the same method that I use. A very clean pair of tweezers usually like number five as they're small enough. Insert into the bottle when they're closed they will pick up a small droplet of oil. When you open them up slowly the droplet will fall off or run down the ends into the oil cups. They just make sure you clean your tweezers carefully afterwards.
  • Like 5
Hold the bottle over your oil-pot...tap the bottom of the moebius bottle with the back of a tweezer, a drop will...well...drop I suppose.
Anil
Not with 9010... it will be an instantaneous spill :blink:
7 hours ago, szbalogh said:
With a medium sized screwdriver you can take outa drop which is enough for 5 watches :)
I find screwdrivers work great for the heavier lubricants like grease
Anil
That doesn't work on this bottle. The other i hade was a little bigger neck on .That worked great.  Without the tapping.
A pipette i think they call the glass syringe with the bubble?
A pasteur pipettes is a small micro pipette .
Thanks al i will look into it . Anyone need a couple of hunded?
Edited by rogart63
I use a screwdriver for removing all oils from bottles.  For the finer oils it takes two or three dips to transfer the correct amount to the pot.  Using this method I have little or no wastage at all.
Best way is what JohnR725 said, use clean tweezers, closed as you enter bottle, capillary action will run the oil up the tweezer, touch down on oil pot and slowly open tweezers, oil runs down in a nice controllable manner.
Take a plastic straw and cut out a strip that is abt half the size of the hole in the bottle and abt 40-50mm long - dip in the oil and then transfer the oil on the curved tip to your oil pot!
If you can find straws with a small enough diameter to fit inside the bottle - just cut to length, dip 1-5mm in the oil - cover the top of your "straw pipe" with your finger - move to oil pot and then remove your finger - viola.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
