I know repair tools are expensive & for me money is critical. So I would like to know if there is an alternative to those huge Staking tool sets I see for sale? I feel this is holding me back in my goal to learn as much as I can about watch making. Replacing a balance or jewels is an essential part of the trade. So what are the options?
Your opinions would be much appreciated.
Thanks
Well, instead of buying a set, you might try and find some individual pieces that are not that expensive to start. First, an anvil which can be as simple as a metal block with some holes in it. Better is an anvil that supports the punch and keeps it square to the work, I've seen serviceable ones sell on the bay for not much money.
Unfortunately,  the punches are very specialized, and I can't think of an alternative off the top of my head. They are, however, also available individually or in groups both new and used, and can be inexpensive if you are willing to clean them up yourself.
I was patient, and finally found a serviceable set used that I purchased for a bit more than $50, you can probably do better than that if you take your time.
My suggestion would be to download and study  material that @tomcolson has so kindly made available here -
http://kanddinverto.weebly.com/
and then hone in on the items you need to do the jobs that you have at hand.
I was also about to point out you can get vintage staking sets staggeringly cheaply, I got a bergeon star set, complete, with extra punches, in fine, precise working order for under £100, though I doubt I could get that good a deal again.
However, yes you can do a lot without the actual anvil and just get a staking block and stakes cheaply and easily.
Mine I got for under £40 I had alot of work to do cleaning it up but it was a bargain you can find them if you look around enough.20160526_001829.jpg
Edited by Cad101
  • Like 5
ebay  ug !    ebay tools and delivery errors are even worse.    there is a need for a smaller, cheaper staking set.    a lot of those punches and anvils  can be made on a lathe.  use drill rod and then  harden it.   vinn
I bought a nice staking tool for under £70 or about $92.  Then i found a set off like new punches at a Swedish auction site. Ebay in  Sweden Tradera.
My situation is like yours. For a hobby i cant afford a complete set, although i am always searching for a cheap acceptable one. Currently for my 1-2 watches under repair i make my own stakes and tools. For me this process is just like as exciting as tinkering with watches.
Edited by szbalogh
Tomorrow i will go to a local flea market. Wish me luck :)
some watch repair enthusiasts have served a trade as a "tool maker".   the  rest of us should know  "when to quit before screwing something up".  vinn
Some self-made "tool makers" here are excellent, posting greats threads and pictures rather than grumpy condescending statements.
Edited by jdm
I picked this up from ebay for a restoration project and I wanted one anyway, so the resto so far is going well.  All the holes in the box have a punch of some type, will upload images when it's finished.  It cost £33.00 or $43.00.
last 3 images are: rusted in box, after soaking in white vinegar, and soaking in 3 in 1 oil.
ebay is going to be your best bet. You can also try Uncle Larry's Watch shop. I bought my K&D 600 series for about a 100 bucks and had fun restoring it. Again, Uncle Larry's has a good selection of individual punches. One thing to watch on ebay is the sets that people are selling that are full of doubles or damaged bits left over from sets they buy to complete the set they already have.
A great way to clean up the stakes is to chuck them up in a cordless drill and use steel wool and then go to 1500 wet dry paper and finally use a quality metal polishing paste. Mine came out looking spectacular, much better than they ever did coming from K&D. The process is gentle enough that I did not change the diameter of the stakes. Use the appropriate caution around the business end of the stakes. You don't want to alter or round  off the ends at all.
Like yourself, I have to buy used and then spend the time to restore...some times I have just as much fun doing the restoration of the tools as I do using them...:)
As a veteran of a number of eBay staking set purchases, I concur with those above that it's a good way to get started. Complete sets in great condition go for top dollar but the prices for less complete sets requiring a little TLC are much more reasonable.
I started out using only abrasives to clean up the stakes as described here. Currently (today in fact!) I start with an overnight soak in EvapoRust to remove most of the rust and convert what's left to black iron oxide. Then I use fine 3M radial bristle disks to polish up the working and marked ends. I take great care with the working ends to insure that I do not round over corners, etc. Usually the highly polished working ends are the least rusted parts of the stakes.
I'm not a fan of vinegar for rust removal since it will remove clean metal along with the rust. EvapoRust or electrolytic derusting will not. An important note about EvapoRust: be sure to completely immerse the objects being treated. Any object breaking the surface will be etched along the waterline (deeply if you leave it long enough). One of my staking sets is very sad that I know this.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
