Hello from South Wales.
Ive just joined after watching many of Mark's excellent videos on Youtube. They have taught me many things and reminded me of many I had forgotten...
I'm now 55 and slowly getting back into watch-repair. When in school at age 12 or so I used to mess around repairing, and by age 16-17 was OK-ish I thought, even tackling an Omega 861 with complete success. I would never contemplate doing one now however!
I Thought at the time that there was little future in watch-repairs as the Q revolution had taken a big hold so went into electronics repair instead I was pretty wrong!.....
Is the age of 55 too old to get back into this?--I dunno maybe, but with lots of loupes and glasses plus a £5 microscope from ebay I manage--so far!
I'm particularly into Accutron Tuning-Fork types and have a number of 'Vicims' I have four 214, four or five 218's, and a couple of 219's most running well
Recently Ive aquired a couple of ESA 9162 types One of these, a very poor Tissot looked as though it had had a very hard life and was used as a donor for others--Even the bezel is missing from the case, Both coils faulty, missing hour-wheel etc, Very sad condition but does have a nice blue dial.
I managed to fix the coils, (the windings themselves were good, or I wouldnt have stood a chance.) The TR coil had a broken transistor and the RC had a high value resistor (4M8 instead of 3M3) so both the res and cap were replaced (One benefit of being electronics engineer!). bought a new hour-wheel, serviced it now its working good, so the hunt for bezel is on....
This afternoon, I'm going to tackle an ESA 9164 in an Omega, See what sort of mess I can make of that!
Welcome back to a fantastic hobby. Like yourself I returned about a year ago after at leased 25 years away and I'm afraid being over 50 means your sight goes but some good loupes a pair of 3.50 reading glasses and good light work for me.
Welcome Alastair belatedly, from me in Newcastle upon Tyne,
It is good to have young blood joining the forum and I am sure you have found a good home for your hobby amongst like minded folk.
Cheers,
Vic
  • 3 months later...
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
