1 hour ago, Geo said:
Without actually trying one, I cannot comment.
All I can suggest is that you read the reviews and make up your own mind.  Sorry not to be much help with this, but without first hand knowledge, I don't want to recommend something that you may not like.
I Guess I should play it safe and go with the one you did like. Although gambling is what I do best :)
Mine arrived today :)
32243374001_cf6c76d3b0_k.jpgDSC04794 by Micky Aldridge, on Flickr
Having checked they work, I'm happy to report they do indeed work, however, with my old set up, I had my tubed lamps plugged into a remote control power lead extension, and I could easily switch on each lamp remotely, these LED lights on't allow for this due to not having a physical on/off switch.
Having press button micro switches, not only do I now need to switch each lamp on physically, the previous light setting brightness level is not stored, and therefore, not only does one have to switch each lamp on via the lamp's control panel, I will need to set each lamp's brightness each and every morning,  Oh humbug.
That said, I'm quite impressed with them thus far.
I use one of these as I don't have much room, and it was so cheap that I thought I'd take the risk. Lights well, though construction is quite flimsy:
http://www.iconiclights.co.uk/industrial-style-linea-led-clamp-on-adjustable-desk-lamp-with-included-bulb.html?gclid=CO6XqrGHztECFQsTGwodzpAEpw
Edited by rodabod
I've heard good things about this Arbe lamp and I was set to buy one, but I got laid off on New Year's eve. So I used some scrap plywood to make an arm for a light I built a while back. It has 6 strips of 36 SMD 5630 leds each. The arm is a bit ugly, but I'll try and pretty it up a bit. I got a chance to use it for the first time today. For the money, it meets my needs nicely.
16 hours ago, ro63rto said:
Don, did you mount the LED strips onto aluminium strips to help dissipate heat during long usage sessions?
Sent from my Honor 5c
The leds are pre-mounted on an aluminum strip and that is inserted into a channel with fins that I guess is a heat sink of sort. Here's a pic from the seller's site.
I use several lights on my bench.
- An original Luxo illuminated magnifier.  This has a 40W fluorescent light that surrounds the 3X magnifier.  It provides general work lighting and uniform object illumination when viewing through the magnifier.
- An IKEA JANSJÖ single LED work light.  This has a weighed base and goose neck arm that allows me to position the light at any angle to illuminate exactly what I need.  The flexibility and power of this lamp is well worth the inexpensive price asked by Ikea.
- A home built ring light on my microscope.  This uses an aftermarket angel eye projector for an automobile HID headlamp and it mounts coaxially with the objective of the microscope. It provides a very very uniform and bright illumination to the work under the microscope, whether that is electronics or watches.  I love this worklight.
SrXzsLw2Eu-iQN1naf1lp7c0evk07X4Xqw7Gk3ny
If I had the possibility, I'd gladly trade the ring light for an AZIZ light from Tangent Audio, but unfortunately this thing is made from unobtanium.
Edited by robmack
4 hours ago, adiorio110 said:
Don
Nice job on the bench and the light. I built my own bench also, wish I thought of building the light, I might do it if I need another lamp.. I did decided to purchase the light that was recommended by I believe GEO.
Anthony
Thanks, Anthony. I love your bench. How wide is it?
On 1/7/2017 at 4:49 AM, Watchtime said:
Thank you...I made it 33 X 18  inches, I figured more room could't hurt. I am getting ready to sell my house cant wait to move. When I do I want to build a full height standalone bench, should be a nice project.
That's nice and wide. Mine is only 21" wide. That must be a huge monitor.
I think it will be some time before I have the space, but I'd like to build a full sized bench too. Both for learning more woodworking and to save money. Just a standard bench is $700-800. Even if I screw up and have to do it twice, I think I can still beat that - and have it personalized to my liking. :biggrin:
Seems we have a few of the same interest. I like to mess with some electronics, wood working now watches.. In general I like fixing broken stuff I am not an expert at anything, but in most cases I can hold my own and get the job done. Thank god for the internet.
https://www.dropbox.com/sh/7usqy0ib4hvkib0/AACtQqWU04bhn6NQHfj6ODiIa?dl=0
https://www.dropbox.com/sh/08brzllftklna5e/AADl5_GJa_vP2TGEyAYat8Cna?dl=0
https://www.dropbox.com/sh/0pbn62e9klcmfzk/AABpDiBtUh4J0X11BwOkmSpua?dl=0
14 hours ago, adiorio110 said:
Don
Anthony
very nice bench that is, well done...
That guitar is great! You woodworking experience far exceeds mine. My bench was the first project of any complexity that I've build. I've got lots to learn!
Don
Thanks. Like I said I'm not an expert and really haven't done many projects with wood other than basic repairs. Its not as hard as it looks. I don't mind buying the right tools for the job. I am sure if you have the right tools you can do at least as good a job. Judging by your desktop, I'd say you have the chops.  My basic outlook on things is, "If someone else can do it, I can do it also" Maybe not the first time, but if I keep at it I'll get it. I think anyone with the right outlook and determination can do anything. Just most people are lazy and/or only comfortable doing what they know.
With all the forums and YouTube videos on any subject your interested in, you can't miss.
Regards
Anthony
Today has been my first official day working with these LED lamps, I've been trying them out on their default setting, and have noticed a couple of observations with them..
Whilst checking the gear train of a movement, whilst it running, the LED lights kind of give a strobe effect to the naked eye.
Another observation, is when I go to take a photo with my camera, the screen on my camera shows a seriously off-putting flickr which is restricting me from seeing the viewfinder before capture.
I will try the lamps on the other settings to see if this is the the norm.  I guess I have become so used to the old tube daylight lamps I had, these LED lamps, whilst great, this is going to take some getting used to.  Not shot any videos under the LED lights yet, so hope they don't cause a flicker issue.
EDIT> I just checked with the LED on its brightest setting, and the flickr on my camera's viewfinder is pretty much gone, there is a tiny bit of the flickr still, but its way less obvious now.
Edited by SSTEEL
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
