1 hour ago, Geo said:
Without actually trying one, I cannot comment.
All I can suggest is that you read the reviews and make up your own mind.  Sorry not to be much help with this, but without first hand knowledge, I don't want to recommend something that you may not like.
I Guess I should play it safe and go with the one you did like. Although gambling is what I do best :)
I've just purchased three of these LED lamps from cousinsuk, I hope they aren't faulty like yours, Mark, but at least if they are. its an easy fix.
Mine arrived today :)
32243374001_cf6c76d3b0_k.jpgDSC04794 by Micky Aldridge, on Flickr
Having checked they work, I'm happy to report they do indeed work, however, with my old set up, I had my tubed lamps plugged into a remote control power lead extension, and I could easily switch on each lamp remotely, these LED lights on't allow for this due to not having a physical on/off switch.
Having press button micro switches, not only do I now need to switch each lamp on physically, the previous light setting brightness level is not stored, and therefore, not only does one have to switch each lamp on via the lamp's control panel, I will need to set each lamp's brightness each and every morning,  Oh humbug.
That said, I'm quite impressed with them thus far.
I've heard good things about this Arbe lamp and I was set to buy one, but I got laid off on New Year's eve. So I used some scrap plywood to make an arm for a light I built a while back. It has 6 strips of 36 SMD 5630 leds each. The arm is a bit ugly, but I'll try and pretty it up a bit. I got a chance to use it for the first time today. For the money, it meets my needs nicely.
Thank you, SSTEEL. I appreciate it.
21 hours ago, SSTEEL said:
Sorry to hear you lost your job, Don. :(
Great creativity there though with your lamp, impressive use of wood, and LEDS. :thumbsu:
16 hours ago, ro63rto said:
Don, did you mount the LED strips onto aluminium strips to help dissipate heat during long usage sessions?
Sent from my Honor 5c
The leds are pre-mounted on an aluminum strip and that is inserted into a channel with fins that I guess is a heat sink of sort. Here's a pic from the seller's site.
BTW, the leds are listed as "daylight". The actual color rendition, but it's actually very good. I can't seem to get the white balance right on my camera.
Don
Nice job on the bench and the light. I built my own bench also, wish I thought of building the light, I might do it if I need another lamp.. I did decided to purchase the light that was recommended by I believe GEO.
Anthony
I use several lights on my bench.
- An original Luxo illuminated magnifier.  This has a 40W fluorescent light that surrounds the 3X magnifier.  It provides general work lighting and uniform object illumination when viewing through the magnifier.
- An IKEA JANSJÖ single LED work light.  This has a weighed base and goose neck arm that allows me to position the light at any angle to illuminate exactly what I need.  The flexibility and power of this lamp is well worth the inexpensive price asked by Ikea.
- A home built ring light on my microscope.  This uses an aftermarket angel eye projector for an automobile HID headlamp and it mounts coaxially with the objective of the microscope. It provides a very very uniform and bright illumination to the work under the microscope, whether that is electronics or watches.  I love this worklight.
SrXzsLw2Eu-iQN1naf1lp7c0evk07X4Xqw7Gk3ny
If I had the possibility, I'd gladly trade the ring light for an AZIZ light from Tangent Audio, but unfortunately this thing is made from unobtanium.
Edited by robmack
4 hours ago, adiorio110 said:
Don
Anthony
Thanks, Anthony. I love your bench. How wide is it?
On 1/7/2017 at 4:49 AM, Watchtime said:
Thank you...I made it 33 X 18  inches, I figured more room could't hurt. I am getting ready to sell my house cant wait to move. When I do I want to build a full height standalone bench, should be a nice project.
That's nice and wide. Mine is only 21" wide. That must be a huge monitor.
I think it will be some time before I have the space, but I'd like to build a full sized bench too. Both for learning more woodworking and to save money. Just a standard bench is $700-800. Even if I screw up and have to do it twice, I think I can still beat that - and have it personalized to my liking. :biggrin:
Seems we have a few of the same interest. I like to mess with some electronics, wood working now watches.. In general I like fixing broken stuff I am not an expert at anything, but in most cases I can hold my own and get the job done. Thank god for the internet.
https://www.dropbox.com/sh/7usqy0ib4hvkib0/AACtQqWU04bhn6NQHfj6ODiIa?dl=0
https://www.dropbox.com/sh/08brzllftklna5e/AADl5_GJa_vP2TGEyAYat8Cna?dl=0
https://www.dropbox.com/sh/0pbn62e9klcmfzk/AABpDiBtUh4J0X11BwOkmSpua?dl=0
14 hours ago, adiorio110 said:
Don
Anthony
very nice bench that is, well done...
Thank You Watchtime. Working with wood is great, it is very forgiving even if you make a mistake. (not that I ever make mistakes). ;)
That guitar is great! You woodworking experience far exceeds mine. My bench was the first project of any complexity that I've build. I've got lots to learn!
Don
Thanks. Like I said I'm not an expert and really haven't done many projects with wood other than basic repairs. Its not as hard as it looks. I don't mind buying the right tools for the job. I am sure if you have the right tools you can do at least as good a job. Judging by your desktop, I'd say you have the chops.  My basic outlook on things is, "If someone else can do it, I can do it also" Maybe not the first time, but if I keep at it I'll get it. I think anyone with the right outlook and determination can do anything. Just most people are lazy and/or only comfortable doing what they know.
With all the forums and YouTube videos on any subject your interested in, you can't miss.
Regards
Anthony
Today has been my first official day working with these LED lamps, I've been trying them out on their default setting, and have noticed a couple of observations with them..
Whilst checking the gear train of a movement, whilst it running, the LED lights kind of give a strobe effect to the naked eye.
Another observation, is when I go to take a photo with my camera, the screen on my camera shows a seriously off-putting flickr which is restricting me from seeing the viewfinder before capture.
I will try the lamps on the other settings to see if this is the the norm.  I guess I have become so used to the old tube daylight lamps I had, these LED lamps, whilst great, this is going to take some getting used to.  Not shot any videos under the LED lights yet, so hope they don't cause a flicker issue.
EDIT> I just checked with the LED on its brightest setting, and the flickr on my camera's viewfinder is pretty much gone, there is a tiny bit of the flickr still, but its way less obvious now.
Edited by SSTEEL
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
