Oops! Barrel arbor screw sheared off.
Maybe should have asked this question a bit earlier:pulling-hair-out:Is this screw ever a left handed thread?
Was happily tearing down my AS 984, until I got to this little swine!  I did get it out but it appears to have sheared off!
Is drilling it out an option, or will I have to replace the arbor?
Any other suggestions as to how I can repair my muck up?
i've only known the crown wheel to be reverse threaded. i have never seen the barrel as such. perhaps it was on it's way out already? i'm not sure if there is an easy out that is that small.
plan "b" is to start looking for a naff movement and cannibalize it.
Oh well... thought as much! I have no idea why it was so tight.  Maybe the thread was
jiggered and had been put in with thread-lock. One step forwards and two steps back.  :huh:
Just when I thought I was getting the hang of things...
Buzz12,
I recently serviced an AS984, and the barrel screw is a left-handed thread as well as the crown wheel. Luckily, when I tried undoing it and it wouldn't budge, I just tried the other way and out it came. Fortunately, the screw was not too tight. A replacement arbor would seem to be the best solution, and you will need the correct screw with it. Nice little movement, good luck.
Frank.
Edited by fjseal
Add more info.
5 hours ago, buzz12 said:
Cheers Frank, that's a first! Never known a barrel screw be left-handed... thanks for sharing. Just learning all the time.
Maybe in this case the crown wheel is right handed and turn the other way around?
Nope jdm, the crown wheel was left- handed as I was expecting. I did try the barrel both ways but not because I thought it would be left-handed but thought it might ease it.  Anyway, Rogart63 has got me sorted so given time it will live again.
Cool. But in the industry there is always a reason why certain things are done a given way, and post-fact is fun to make guesses. Perhaps it has been made so for commonalty with the crown screw?
Fjseal is spot on, I have just checked 2 in my collection, a 7 jeweller and a 15 jeweller, and in both cases both the crown wheel screw and the ratchet wheel screw is a lefty. Unusual, but not unheard of.
Crown wheel screws are usually (but not always) left handed as in most cases the screw is threaded into the barrel bridge and so shouldn't turn, and the crown wheel turns anti-clockwise when the watch is wound. There is therefore a risk that torque could be transferred from the crown wheel to the screw in which case a right handed screw would start to undo. By using a lefty any torque that may transfer from the wheel to the screw would just tighten the screw. In an ideal world though there should be sufficient clearance between the screw and the wheel for the wheel to turn freely when the screw is tight.
The ratchet wheel screw on the other hand is screwed into the barrel arbor and so rotates with the wheel. There is therefore no risk of torque transferring from wheel to screw which means that either left or right handed threads are fine.
As Jdm suggested, this could just be  so that only one type of screw is needed for both functions, and not two, thus economising on manufacturing costs.
  • Similar Content
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
    • Yes Breguet overcoil, and A is OK, the damage is from B to the end. It should look lile this. The studd is fixed by the screw head into  the cut.
    • I opened up a 17 jeweled Swiss made movement only to find it has a pin pallet escapement. Not sure where the 17 jewels are but they ain’t on the pallet fork! Tips for lubrication?
    • Hi, This headstock is a little bit too modern for me to know my way round it. The pin that stops the collet spinning is sheared and needs replacing. Does anyone have advice on how to remove the spindle? I’m assuming that you remove the quick change assembly from shaft. Remove pulley. Unscrew front and back bearing plates on the headstock. Then press the spindle out applying pressure to the front (collet end). Has anyone done one of these? Any pictures or links to articles/literature gratefully appreciated. Thanks in advance. Warm Regards   Andy
