Chinese Timegraphers
2 hours ago, mikepilk said:
I'm checking the capacitors and getting odd results with C4,C5,C6 and C10. So I tried them in beep mode, and can get them to beep with the probes connected in either direction. Is that a faulty cap, or could it be a faulty C108? …
If you got at least the beep the capacitors should be o.k.!
I also think that the CM108 is defective 😞
If you were nearby I would be happy to investigate your device further having my working device for comparison. I even have a hot air station 😉
Indeed. I would double check. Now you have a new meter to aid your teating.
I did, and it is actually working. If I ignore the instructions I can get it to work. I set the voltage to 5V and limited the current to 0.5A. When connected directly to the board, SPKR (GND) and R3, the board is drawing 0.02A
I put the meter in line - reads 0.025A (and 0.28V at C1)
Edited by mikepilk
But a beep in both directions ?
Thanks for the offer and help. It only cost me £27 including postage, so no great loss, and not worth trying to change the chip. It only lasted an hour, but has given me hours of entertainment.
The key is follow the correct instructions!
In CM108 datasheet version 1.3, suspend mode power consumption is 320 mA.  I don't believe that.  Way too high.  Speaking of specs that are way too high, can your new "60 MHz" meter measure the crystal frequency?  Then I found CM108 datasheet version 1.6, and now suspend mode is 300 µA and total power consumption is 70 mA.  That makes more sense.
But we must also consider the the LM386 amplifier section is drawing power too.  This part is a little more analog than what I work with.  But I have another Chinese 3d printed microphone with a LM386 amplifier section and an analog out.  At 5V it draws about 4 mA.  So assuming it's the same here, that leaves 16 mA for the CM108.
That's too much for suspend mode.  But not an obvious short either.
Depopulating R6 and C16 would disconnect the CM108 from the amplifier.  The idea is somehow the amp section is drawing too much power from the mic bias output.  Other than that, I think the CM108 dying is the only other explanation.  Probably some flaw in the board design allows the maximum limits to be exceeded, rather than a piece of silicon just up and dying for no reason.  Voltage from the lm386 out of limits?  Or maybe the amp continues to supply power from the big cap after USB is disconnected and Vdd is 0V, so it exceeds a MICIN > AVdd or VBIAS > AVdd limit?
On 1/31/2023 at 5:23 AM, TGX said:
Do you know anything about the SPK pins? Since this is a USB audio interface, maybe you could play audio from PC?
Yes, it can.  It even showed up on the computer as an output while it briefly worked.  The CM108 recording function can be disabled, but the line out can't be. Two 470 µF capacitors should be in C2 and C7 to connect the line out pins to a socket that would mount into the holes by SPK.
Measuring the capacitors in situ isn't going to work well.  But it's not really necessary as they aren't going to fail by having an incorrect capacitance.  They are just a point where a solder bridge could exist and create a short.  They could also become disconnected from poor solder joints.  But I think the band gap and regulator in the CM108 should still work (and they aren't) even with most, if not all, of the capacitors removed.
It was following the instructions on the power supply that led me to the conclusion it was faulty. To set the current limit the instruction is to set the voltage to 3-5V, short the terminals, then set the current. But that doesn't work, it never registers a current. So now I set the voltage to the desired level, use the meter as a load in current mode to set the current limit.
 No, I think you are right about the limits of the meter, I got something but it didn't make sense.
Thanks for your knowledge and patience. I love learning new things, and I have. I'm watching lots of Youtube vids on fault finding electronics - I'm probing everything 🤪
22 minutes ago, mikepilk said:
What does that mean - would it have damaged it ?
No, it would not have damaged it.  Just might have stopped it from oscillating due to load impedance.  But as noted earlier, this is an oscillator can, so it has a low impedance output and would not have been disturbed but the loading of the meter.
  • Similar Content
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
