Custom Watch Timing Stand
jdrichard
instead of a pin for the level, you could make the top part of the stand bigger around the axis point.  Drill small countersinks on the "in" side at the 12,3,6,9 positions and have a spring-loaded pin in the aluminum to interface with the countersink/detents.  This would provide a positive engagement at the 4 main positions without requiring any fiddling with pins to move into or out of the horizontal position.
I think my only option at the moment is "rubber bands" to hold the movement in place. The other idea would be to devise a clamp that would blanket over the movement?
From Canada
From Canada
4 hours ago, jdrichard said:
I need you to sketch this out. I'm an engineer and need pictures, words just confuse me.
From Canada
something like this:
the "detent ring" would be on the stand and the lower part he doesn't adjust would be the AL holder.
A clamp only needs one moving part.and a fixed base - if you use the same shape the regular ones use, i.e. little "C" shapes that cup the sides.  You could use pins and get away with w fixed and one moving.  the movement could be adapted from the various movement holders.  Put the two fixed pins at 10 & 2 and have the moveable one at 6.  One immediate complication that springs to mind is making it band-compatible.
Thanks. I will investigate tonight and get back.
i suck at drawing.  your stand device has two parts: the stand part and the movement/watch holder part.
on the movement holder, source a spring that fits in the hole you've already drilled in it and a ball bearing that's a tight fit.  jam the ball bearing over the spring and stake it into place.  the spring needs to be long/strong enough to push the ball bearing out at rest.  As you rotate the movement holder about its axis, the ball bearing now describes a circle on the stand.
you now need something that is a dupe of the click ring in the video, the little brass disc he's holding.  you would have 4 divots if you want 90* turns; 8 if you want 45* like in the video.  You need the divots at the specific radius described by the ball bearing.
you could machine a separate disk and pin it (like a dial) into the stand piece.  or epoxy it.  or create a new stand altogether with the divots integrated.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
