Locked escape wheel.
Working on a Vostok 2414, I fitted a new escape  wheel and pallet fork. When I activate the balance wheel, the escape wheel moves but does not advance. In the picture, the position of the pallet pin is with the fork as far as it will go against the banking. If I filed a small amount off the solid banking, I think it would solve the problem. Is this permissible practice, and has anyone encountered this before. I don't think the watch is far enough out of beat to cause this, also the same thing happens when tested with some wind on the mainspring before the balance is fitted; the escape wheel will not advance. I hope the pictures are clear enough. Thanks.
Frank.
Edited by fjseal
Add another picture.
Is the pallet fork installed right side up ? Usually the pallet jewel on the longer arm is to the left . Is the impulse jewel on the balance between the fork fingers ? With out the balance installed you should be able to tickle one of the gears to see the escape wheel and pallet fork engage and move the pallet fork left and right . I don't think that I would file the the solid banking to solve the issue .
Not knowing a whole lot about watches; but I can't see the guard-pin (#4) on your pictures? To my humble mind this one should be visible from the side the picture is taken from. Unless the 2414 pallet hasn't got a guard pin or the pallet is the wrong way around like ricardopalamino suggested??
Picture just for illustration of the parts / names, I know it's not Swiss ;)
Thank you for your replies; Endeavor,  the guard pin is there. On another website there is a walkthrough of this movement, and the pin is facing down. Because of the different length of the pallet fork pivots I think it is impossible to fit it the wrong way up. The other thought that ocurred to me was that the pallet pin may be set too far out. Incidentally, the new fork came with a new escape wheel.
Ricardo, the escape wheel does not advance even without the balance fitted, and tested as you suggest.
29 minutes ago, Cad101 said:
Have you tried it with the new escape wheel provided with the new fork.
OP said: "I fitted a new escape wheel and pallet fork". Seems like one of these is faulty.
Sounds like you haven't got the balance wheel in the right position? Loosening the bridge screw and rotate the wheel until it engage with the pallet fork. The jewels hits the outside of the fork instead of sitting inside it. Happens once in a while for me at least.
But as the OP mentioned above, the escape wheel does not advance even with balance removed and the tip is moved manually. That is a fundamental test.
Ooops. Then there must be some other problem?  Remove the pallet fork and work his way backwards.
It's very easy to put in a pallet lever upside down thus making it impossible for it to interact with the escape wheel properly.
Don't ask me how I know this.
Dave
Not sure about Russian movements, but it's impossible with the Si
What ever you do don't touch the banking pins because if you do you will end up with all sorts of trouble.  The first thing I would do is release all the power, remove the pallets, put a little power on and see if the train is free, make sure all the train  has good endshake, inspect the pallets make sure the pallet stones are are set firm and pallet jewels are ok, put pallets in making sure the pallet bridge is fixed, add a little power and make sure the pallets are free up and down and have good endshake, now touch the pallets with your tweezers and see if the escape wheel will escape. Try that first and let me know.
9 hours ago, jdm said:
Sorry. With Seiko.
Ah, so no silicon then? Was wondering...
I know nought about Russian watches except that a woman I met who was from Russia had been saving for a car and because of the devaluation of the Rouble she was only able to buy a Russian-made watch.
Update:
Thanks for your advice oldhippy. I have followed your procedure...I am happy that the wheel train is functioning perfectly, no binding of obstruction. It's almost as if the escape pallet pin is set a little too far out of the pallet fork. The mainspring is new, but the fork does not 'flick' confidently like you would expect it to. I will attach a photo of the new  pallet fork so you can judge if it looks normal to you. How much 'endshake' should the pallets have?
i might suggest putting one or the other of the old parts back in and try it. try the new pallet with the old escape wheel and vise versa. is would seem that one or the other of the new parts is faulty. i know that is a stretch, but it can't hurt to try it.
Edited by ramrod
To me that pallet stone is set wrong, trying to line it up it looks to me to be out of line. I cant find any info on pallet end shake So touching the pallets when set into the movement the pallets wont escape, have you tried a little oil on the pallet stones, then oil the balance pivots and fit not forgetting the shim that goes under the balance cock and screw tight making sure the balance staff is set in the jewels.
Here are two pictures I have found with pallets fitted and the pallets stones can be seen clearly that stone is not set in the same position as yours, there for I think yours is at fault and that is the problem. Sorry if you think I've gone all over the place with this but this is something you might come across and is good practice in fault finding.
Easy to do!
I am in watch heaven; I got 5 junkers from my watchmaker friend!! Some good names too, Seiko, Lorus, Caravelle, etc...
I just de-cased the Seiko; something I'd never been able to do w/out one of Mark's videos on the subject.
Back to the bench...
Dave
    • When can you use a standard crystal to replace one that had a tension ring? The first time I popped a crystal with a tension ring out of a watch I found that I had a suitable sized standard crystal and decided to try that.  It fit nicely and it was hard to see that anything was missing from the watch.  I understand that it probably reduced the water resistance of the watch but since it was an old dress watch it wasn't going for a swim anyway! I have since tried the same thing on another watch and found that the tension ring seemed to have an additional role of holding the dial in place.  With the standard crystal in there the dial and movement falls forward. This means it rattles in the case and falls forward and the hands fowl on the crystal (when the dial is down). Is there a trick I am missing here or does this watch require a special crystal?  I am reluctant to buy an expensive armoured crystal only to find I have the same problem.
    • So I wrapped the anvil it in bubble wrap and passed ot through the demag only. Still no go—the unit is simply too strong.  next experiment is to use a VARIAC to lower the voltage and see if that reduces the magnetic field.
    • In this case, the underside of the crystal is flat so I assume I don't have to worry about clearance to the hands. However, perhaps I'm missing something. If so, please let me know. I guess no one has the patience to get into the details of my first post so here's a simplified version of my question: The case diameter for the glass gasket is 36.9mm. However, Cousins doesn't have a glass gasket with that diameter. The closest are 36.8mm and 37.0mm. Would any of those two options work, and if so which one? I have no problem ordering both and testing them, but If someone already knows it is pointless, there's no reason to order. No, I haven't. Is there someone you can recommend? Preferably in Europe. Thanks!
    • No. It's incredibly volatile and evaporates in seconds; there is no way it would last as long as it took to just install the part cleaned in it, in the movement.
    • When I record how much I have spent on each watch I include the postage.  UK EBayers seem to be charging £5 minimum these days on postage.  Have made a couple of job lot buys recently - based on the average price this one could be 404 reboot project  Bad photo from eBay - 1 of 4 watches for a total of £21.19. A Medina with an MST 385 movement - Soaked in oil but looks like it will run again!
