My Absence
Hi everyone,
It's ages since I last posted. Probably about Sept. 2014 when I had a very nasty accident whilst cycling on a cycle lane in Worthing, West Sussex.
Somehow I managed to collide with another cyclist and landed head first on a lump of concrete. Stupidly I wasn't wearing a safety helmet.
I was air lifted to St. Georges Hospital in London, where I stayed for a week and to cut a long story short I have needed further Hospital treatment since.
I have recovered and I'm now more or less back to normal, thanks to wonderful help from The Air Ambulance, Police, Doctors and Nurses.
Needless to say I now have a helmet.
I'm now back with the watches and will be posting again shortly.
Bye the way thanks to the WRT staff for the E-mail dated 20/01/16.
Regards,
Richard.
Hi Richard - well, very sorry to hear about your accident - and very glad to hear you're getting back to normal!
I live in Henfield and occasionally venture to the wilds of Worthing. Obviously a dangerous place without a helmet!
Regards,
Will
Hello Richard,
Welcome back and it is good to hear from you again.
Sounds like you have had a rough time of it and thank heavens for the Air Ambulance which is a great Service. The Great North Air Ambulance do valuable work where I live, incredible that they have to rely upon Charitable funding to exist at all.
All the best,
Vic
    • I went with 8.90£ because 12th century Italian mathematicians are always excellent topics to bring up when trying to get your guests to go home.
    • As a beginner, I’ve found this forum invaluable. I doubt I would’ve persevered without its support. I’ve had the confidence to attempt things that seemed to me impossible only because I knew there were patient and giving folks gathered around this watering hole, available to share their skill.    I would very much like to know where to go if this one dries up and everyone needs to decamp.  There’s something special about the folks gathered in this group.  How to keep in touch?
    • After a 3-week work fiasco that took up 137% of my time, I was finally able to get back to restoring a G. Boley 8mm lathe I picked up on eBay. I still need to do a bit of polishing on the tailstock but it works very nicely. Before and after pictures below. In any case, when I was reassembling the motor I wasn't quite sure which side the pully attached to, or if it matters. My question is ... does it matter? The listing photo below shows it the reverse of how I have it now, but it seemed that the cord and the reversing lever(s) should be on the right away from the belt.
    • Thanks Richard.  That’s clear.   So - another question - how much latitude is there in barrel and spring sizing? Say I have have measured the ID of my barrel to be 9mm and (all other mainspring specs being equal), the closest match I can find for a replacement mainspring is listed with an 8.5mm barrel size, is it acceptable to fit the smaller spring in to the slightly larger barrel without compromising anything functionally?  I’m in this situation now with an AS 1686 which has a 9mm barrel, but the closest replacement I can find has an 8.5mm diameter listed in its specs.  I can find an alternative 9mm spring, but would have to accept a different thickness.  I’m unsure how much wriggle room is acceptable, or whether in mainspring sizing, there’s a priority - ie thickness over barrel size etc. Thanks again for any info.  Cheers, John
    • We already have a Facebook group run by Mark , so this is a bit moot. Search for “Watch repair lessons” group.   Tom
