Seiko 6139 Repair And "restoration"
Thanks ww, its maybe not as much of a bodge trick that i thought it was. -
By watchweasol · Posted
In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok . One was on an era movement, -
Would the paint increase the resistance of the coil ? Effectively joining the wires that are painted. I imagine its important to only paint the smallest of areas to make the repair.
