Screwdrivers Choices
But you are all missing the point. The final mark of quality is that the blades should be dressed with the Horotec or Bergeon twin roller sharpener that produces parallel faces at the blade end. $$$$$
It does make a lovely job Colin, but not required unless you just have to have hollow ground blades.
As others have said, it's the quality of the blades that's the most important factor.
However, I decided to treat myself to a recent birthday present with a set of VOH screwdrivers, they are an absolute pleasure to use (and have a nicer feel than any Bergeon, Horotec or AF that I've used).
post-1141-0-93290200-1446762517_thumb.jp
But I also use various other screwdrivers where one of the VOHs isn't suitable, these are mostly tailored and dressed for individual tasks, here are about half of them  :biggrin:
And also as others have said, shaping and finishing the blades is critical to maintaining good tools and reducing the risk of damage to scres and other delicate bits.
post-1141-0-25424600-1446762709_thumb.jp
Edited by JimInOz
I suppose this is a "sentimental" 2.5 mm screwdriver issue, otherwise I would get a different brand, readily available from your preferred -- read expensive -- brands, whichever one you choose. The nice thing about screwdrivers is that there are tips available separately so maybe, just maybe a VOH for say, 2.0mm tips, with a little elbow grease may "host" a 2.5mm tip...of course the color code will be screwed up...pardon the pun.  :)
In any case, I hope you find what you are looking for.
Cheers,
Bob
They are as good as Bergeon and the tips fit each other. Some people are partial to them rather than Bergeon. Also they offer different models just like most everybody else. Honestly, I made my set a little bit of everyone so I could compare and am using mostly the cheaper Bergeon one (about $100 set of 9). All that said, it is mostly out of habit rather than because of niceties. The rubber covered ones are probably better to my taste but somehow they still get second choice. Go figure! In the end it just a matter of habit and individual preferences...at that level of quality.
Hope it helps your decision,
Cheers,
Bob
I'd hold out for a VOH and only get a cheapy if you really need a 250.
I think it would make you grit your teeth every time you saw the **BLEEP** child among your VOH beauties.
I know it would me.
Best of luck with your hunt.
Cheers
Jim
post-1141-0-21308000-1447717269_thumb.jp
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
