Hello Everybody,
Is this a fake Rolex, it looks real to me but it's really cheap so I'm doubtful.
Also, the winding stem is out and the seller says it want go back in, could this be a big problem or just the keyless works need to be reassembled correctly.
WhatsAppImage2024-08-15at10_04_04.thumb.jpeg.68acf1e4fe9a23f77c0f028d3726b611.jpegWhatsAppImage2024-08-15at10_04_04(2).thumb.jpeg.5ac7fda1d95a5320cf03b1cec33f7fed.jpegWhatsAppImage2024-08-15at10_04_04(1).thumb.jpeg.21286a72b18e88a9a707a438e10d8f2b.jpegWhatsAppImage2024-08-15at10_04_03.thumb.jpeg.498ecf055134e9420080a153199a2b54.jpegWhatsAppImage2024-08-15at10_04.03(1).thumb.jpeg.ebb4bf1f907b8b1dbb36fa63347f5047.jpegWhatsAppImage2024-08-15at10_04_05.thumb.jpeg.5bf79d4bfaa5b4df32d641611969560c.jpeg
2 minutes ago, RichardHarris123 said:
Ask for photos of the movement.
I did, the said they cant open the case back.
Looks like a horrible cheap copy. Look at the poor quality of the bracelet ends, and the notches round the edge of the back are not sharp.
The diamond does not line up with the hour marker, the graining on the case looks poor, the hands don't look right etc etc
image.png.66f3d9420cf15a3d99533d544a9db631.png         image.png.58d471d8c1ed4c7f5475a5c9b35e2758.png
Nothin like an experienced eye.
Thank you sir.😁
42 minutes ago, watchweasol said:
Hi unless you can get to see the movement. I should leave it alone, what’s tha asking price.
Hey, Yes I'm not buying it, the price is around $15 delivered.
I bet it has one of them crappy 0 jewels movement inside it since the seller said its automatic multiple times.
Doesn't Rolex give a referrence No on case back?
 Problem with online purchase is you don't have the watch to put on timegrapher and let the escapement tell you stuff about its heart.
What if the seller brought this to your door?   Can you tell by just its appearance?  Did you know, that weight of the piece is one specification of a genuine Rolex.
Many don't have a timegrapher,  but we can at least  download a simple app off the net, I have WATCH ACCURACY METER  app,  on my smart phone. Very simple , all you need to use it is your hand set.
Some of the replica movements are getting very close, BUT they have not replicated the free sprung balance. All have regulator pins (as shown in this pic from the video), and not Breguet overcoil.
The video is worth watching.
My sifu said that it's not because the Chinese cannot produce a 100% fake Rolex. The video already said that there are things in the fake that look better than the original.
The reason they don't do it is lest they themselves can't tell them apart.
If they could produce a 100% copy, they would. They don't because it's too expensive to copy the free sprung balance.
Are you kidding ?
Why would they be worried about that? These watches are produced to con people. Otherwise they would stamp Chinese Made on them somewhere.
3 hours ago, AndyGSi said:
Also looks like the complete pendant tube has been pulled out with the crown instead of unscrewing it.
To me the crown and to just look suspicious.
1 hour ago, watchweasol said:
Hi Ammar,   Fifteen dollars !    No way is that a Rolex but for a curio may be worth a punt even if it’s scrap it’s worth practising on .
To be fair, you can get a surprisingly good deals sometimes, I just bought a Certina DS in great condition for like $25 (the date change wheel is missing but we don't like to talk about that).
I'll buy this watch and post a photo of the movement, this should be fun and I might have a working watch at the end that I can give to somebody.
Hi,
I received the watch and to be honest the movement isn't as bad as I expected, it's not great neither but it's good for practice.
2 hours ago, mikepilk said:
Really, are you sure? Look at that quality of that cheap Chinese movement 🤣
 I think I see graining on that rotor.  It’s definitely a high end cheap Chinese movement 😝…
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
