My 1960's Glycine Airman
pgse14
Tempting, but unless you're feeling extraordinarily charitable the right price is certainly going to be beyond my current budget . Having just changed from self employed contracting on a weekly invoice to salaried I have a whole month to get through on almost no money. I hope you get a good price for it though, it's a corking watch and has been on my wish list for some time now. I will get one when the time is right.
It runs keeps perfect time has brand new wild boar leather nato strap and has been cleaned and repolished and it was a majors in the us air force and he was an astronaut so it has some history to it its a great watch
Sent from my SAMSUNG-SM-G925A using Tapatalk
  • 4 weeks later...
Nice job on the watch pgse14 ....
.I picked mine up at the swapmeet for $15 a couple of years ago . I didn't know what it was . It had a crystal so crazed I could barely make out "Glycine" on the dial , and I didn't know what that meant . It had a super cheap SS very fake Rolex watchband on it . I just knew it was Swiss Made from the 10 sided Hex style case back . I came home and looked it up ...my eyes got big and I mumbled "Oh Wow" .
  I put a new crystal with the parabolic [i think} magnifier and a canvas watch band with cordura lining . I read that they were sold with canvas watch bands .
Luckily the hacking feature is working on mine...the little wire that comes out of the case and dial at 12 O'clock when the crown is pulled out to slop  the second hand.
The pics I'm attaching are from when I cleaned up the bezels on the Airman and my Zodiac Sea Wolf...a Vietnam Era watch popular with servicemen .
I,ve also attached a pic of an actual Airman wearing the watch .
  • 2 months later...
i love those glycine watches. every time i see them - especially the newer ones, i get all googly. they are sweet. a classic older tech style watch. classic good looks.
i wonder if the older ones that you guys have are radium dials? any way to tell?
I don't have the answer to your question but I have included a link to the information I looked up when I got home from the swap meet with mine .
http://ambwatches.com/category/glycine/
that is a great read. i could imagine that someone could make a killing if they made an aftermarket hacking mechanism. what does it look like and how does it work?
is the case water resistant? interesting that they incorporated that hacking mechanism in the case rather than the movement. really cool.
is the case stainless or plated?
I got
I got a little nervous , I couldn't find my watch...but it was in the first place I looked , but I overlooked it . Whew !!
When you pull out the crown a very tiny wire comes out of a hole between the 2 and 4 at the 24hour mark . It's so small I had to use my loupe to see it . I never inspected the hacking when I changed the crystal a while back so I don't know how the wire is connected to the setting mechanism . It only comes out far enough to stop the second hand .
  The case back is a ten sided design that you would need the right tool to open it . I don't remember how I opened it before . I probably carefully used a crescent wrench , [sorry , I was a newbie . I would not do that now ] , or glued a nut to the back to open it and removed the nut and crazy glue with acetone .
  The case back says , stainless steel , Swiss , automatic , waterproof , Incabloc , pat. 314050 on the edge . The serial number is in the center portion and it's # 601412
The crown on my bezel lock is not cross hatched for some reason .
Edited by ricardopalamino
a lot of older watches are plated. that is much of the reason why i don't usually but older ones. the swiss or european watches seem to have plated a lot of theirs. the japanese seem to use SS. i was hoping that the glycine would be ss. i have it as sort of a grail watch.
im fascinated by the hacking mechanism. it seems so unusual for a higher end watch to have such a thing that (seems to me) could be so touchy or prone to damage. now, having said that, how in the world does it remain waterproof?
it's a very cool watch.
    • Welcome! To which part of India will my greetings go? Frank
    • I agree with @Waggy, no need to adjust. That looks very good to me. The factory specs for 7S26 are something like -35 to +45s/day, but they are usually better. The amplitude is good. When wearing, the most important positions are dial up, crown down and crown left. You need to regulate so that these positions average out to about zero. Crown down is showing +14, so you may have to set dial up to slightly minus s/day. The absolute values of +/-s/day don't really matter, as long as they aren't too far out. The only way to get good accuracy is to wear it for a couple of days, recording the errors, and gradually tweaking.
    • @Jon The link is no longer working and I wanted to see that demonstration again. Is there any chance you can make it available again? I'd appreciate it!
    • Or, if you have a staking set or jewelling too, just use one of the stumps. You can choose a fine tip to fit inside a jewel if necessary.
    • Good morning,   To be honest, I'm not sure I trust my own logic anymore 😅. But here's a picture of my own (failed!) attempt to install a new rotor axle. I punched way to hard and even split the metal of the rotor. My thinking was that, in my case, the axle sits "deeper" in the rotor and hence the rotor would be closer to the movement plates. Vice versa, I was thinking that a very light punch could cause the rotor to sit rather high. But not sure that makes sense because in both cases, the flat part of the axle and the rotor align equally.     Sorry, but is he saying that the outside of the caseback has been polished to such an extent that the inside of the caseback has deformed/sunk??? That sounds crazy to me because those casebacks are thick! Can you see any signs of that on the inside of the caseback? Have you tried screwing in the caseback a litte bit more or less so that the supposedly "sunk" part of the caseback would move from 9 o'clock to e.g. 6/7 or 11/12 o'clock?  If the caseback is truly deformed, maybe it could be punched/pressed back into shape (e.g. with glass/caseback closing press).      I agree with your choice. But yea, Rolex makes it VERY hard for independent watchmakers to do a perfect job because we can't get (original) parts easily.      Your pictures aren't too bad. But still impossible to see if the rotor isn't perfectly flat. You'd have to look at it with your loupe, from the side (like the pictures), and turn the rotor to see if the gaps (with the automatic bridge plates) increase/decrease.     Finally... how is the up/down play of the rotor? To test, take a toothpick/pegwood and press on the small triangular side of the rotor next to the axle (NOT the big side where the weight is. But the opposite side.). Does that lift up the weight-side of the rotor? There can be some play, but it should really be minimal. If there's too much play, a new spring clip is the first thing to do. After that, one could play around with the jewels. This is too much:
