Hello!
GrahamO
Hi to all. I have been dabbling in watch repairs for some time but have only just stumbled across this website. What a great resource. I have been looking at one of the posted videos (on hairspring adjustment) and have learnt a lot already.
Hello Graham!
You've had the good fortune to light upon the friendliest watch forum on the web, with members who'll give you solid advice and with a superb video resource provided by Mark.
What we all love is photographs of whatever it is you're working on, be it ever so humble. I've still to commence my first service but I like to post up items that I've bought, to elicit opinions and information about them.
What's your latest project?
Welcome to the happy house if horology Graham.
Please join in with the fun and post some of you exploits. As the others have already said, there are all types from varied backgrounds and at all levels, but the one common thing is we all like helping one another where possible.
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
