 Lets see TG print outs and  the max delta in various positions.
Having bought  so many fakes,  I can claim expertship now.  😩
Usually Tudors indicate Chronometer on the dial, then officially Certified follows.
There might be exceptions that don't, but TG reveals the heart.
I bet my two cents on FAKE .
Depends on the model.
Looking at the Tudor website the model ranges that do not state "chronometer" or "officially certified" are the Ranger, Tudor Royal, 1926, and Clair De Rose.
LWS's watch looks similar to the styling in the 1926 range, although the current range appears to feature at least some numerals on the dials, I can't see one that is batons only, so the jury is still out.
Why not to glue a M10-Nut with Cyanoacrylat (Superglue..) to the back,
afterwards it should be possible to unglue with Acetone, this was the Solution
for some Cases as reported in this Forum. Or else buy a 5537-Clone Set from China......
regards,
Ernst
regards,
Ernst
That is a great method which have used. But I have never used it for reinstallation.
So, is the oscilator in above models  COSC certifed chronograde ?
Thats the $200  question.
19 hours ago, LittleWatchShop said:
I need to get a tool to open these, but I don't want to spend real money...any ideas
I've seen people claim that the ball used for removing screw backs can remove Rolex backs but if the back is on really tight you do need the tool.
Another thing the use rather than superglue is epoxy. The interesting thing with epoxy is that if you drop the back a pot of boiling water then there is no problem taking off whatever's glued together. I learned that trick from the material house the used it before removing crystals that were  epoxy  in the epoxy basically gets soft.
Sorry folks, insufficent info in my previous statement.
I think LWS has a genuine Tudor, its oscilator is Chronograde but the watch doesn't have Chronometer complication.
So Marc said it correctly.
I tried the ball with my Rolex without success 😉
I continue to lean toward Genuine…
...although...seems that the serial number should be between the lugs
A genuine Tudor:
Listen to the heart.
 A low grade ETA  balance complete can be fitted into  a Chrono grade Tudor, but the Tudor  then runs only as good as a $400 west end watch.
The tg print out you posted is a poor listener and analyzer, yet I believe you have a genuine Tudor.
On 2/4/2023 at 2:20 PM, LittleWatchShop said:
I got in trade for a clock repair. I put about $50 worth of parts in the clock
So, with a little more data, I will be convinced that it is genuine.  I will give it back to the guy I made the trade with.  At the time, I thought it was a copy and so did he.  He was kinda clueless, so whatever he thought about the watch is not a data point.
4 hours ago, LittleWatchShop said:
Yup.  Its the real deal.  Has an ETA 2824 movement.
Haha,
I want a thums up from nicklesilver on this one.
