On 2/19/2022 at 12:51 PM, HectorLooi said:
Nice!
That's the only weakness in a Vigor crystal lift. I salvaged the coiled spring from an Indian-made crystal lift that I wrecked and replaced the worn out oring in mine. Now it should last for another 50 years.
Supply houses carry a replacement rubber band for like $8 which seems a bit high.
I stole the coiled spring from a chinese crystal lift for my vintage Vigor as well.
3 hours ago, LittleWatchShop said:
Didn't know that!  But, at any rate, the printer and a little time solved it.
Oh wait, more like $4.
https://www.esslinger.com/replacement-rubber-ring-for-bergeon-4266-crystal-lift-tool/
Which flexible are you using? i have some TPU filament but i think all of it is shore D95 or something. Heel of a man's shoe sort of durometer. It is not soft.
I believe that if i knew the proper name for that coil spring band, or at least what they might call it in china, it should be possible to buy those too.
Edited by TimpanogosSlim
My crystal lift band snapped not long after I got it.  I just replaced it with a 200 series o-ring.  I got mine from work, but they can be had at any home improvement center.  You just need to know your size.  If you still have the original, take it with you and get one as close as you can to the ID.
  • 1 year later...
On 2/23/2022 at 5:25 AM, KarlvonKoln said:
The ones with brass jaws - are they the Chinese ones, or Indian?  Mine has brass and I wonder now where it was made.  It doesn't seem to say.  Outside of the jaws being a bit rough at the edges when I got it, the lift works rather well.
Since I couldn't get a deal on a vintage one off of eBay, I got a budget one from Esslinger.  The teeth look to be brass.  I did have to do a good deal of deburring to them but it was worth the effort.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
