I bought this watch in 1968 and am interested in getting it running again. It is a "t Swiss Made t", it has tritium dust inside the case and the second hand has rust on it. I wanted to open the case back and see if it has rust inside but can't figure out how. I've already scratched it 3 times and figure I can polish that out but I quit until I know what I am doing. Can anybody help. I thought it was a press fit and would just pry it off but their isn't any space to fit any tool. I used a Bergeron pry tool but again, it won't catch any where on the case back. Any help would be appreciated. Also if you know of a watchmaker that might be interested in tackling a service on this let me know.006.thumb.JPG.9633c9e2b2c3b13b3a08bfdb193580ec.JPG this one let me know.010.thumb.JPG.9cdda9ed63d4d85c760b4847850036c8.JPG
Edited by tarrda
misspelled words
I think I can see a little tab sticking out of the caseback, around the 2 o'clock position. That is the place to insert the caseback knife.
Opening a caseback is no so much a prying action but a wedging one. My preference now is a Seiko style knife. It is a short stubby blade, more like a chisel and is pushed with the palm of your hand, rather than your index finger.
If the watch has be worn a lot, rust, sweat and dead skin cells could have collected in the cracks and seized up the caseback. I like to use a wet toothbrush to clean up the case first, to wet and soften any organic matter. This also prevents debris from getting into the movement once the back pops off.
Try these tricks first. If it doesn't work, then we'll guide you through level 2 opening. 馃ぃ
I'm tempted to think this is a one piece case because the writing on the back is prefectly centred!
The usual way to get into these one-piece case is to apply force on the crown but on some there will be a release that is visible with the crystal removed.
Anilv.
I suspect it is a really tight snap back case back. You might need one of these because when really tight scratches and un necessary marks can happen with a case knife.Also when re fitting a case press of some sort will be needed to re fit.
I have a 1974 Set-O-Matic Oceanographer 666 Feet with an 11BSACB, which is a re-badged AS2066.
  • Similar Content
    • The other thing that makes pallet forks like this interesting is or some of these interesting it when they're not level they don't fit well on the pallet fork warming tool and melting to shellac becomes a challenge. One of things you want to do when working on vintage pocket watches is accumulate broken pocket watches and swiped the jewels from them. Because as you're finding out the vintage jewels were probably not made out of Sapphire there are made out a Garnet and Garnet doesn't seem to hold up as well as shellac. Then the last little part about stones pointing in different directions doesn't make sense? There's always a left stone a right stone angles are different and they both have to be in the same direction. Although I once had a pocket watch command were somebody put one of the stones in backwards and surprisingly the watch ran. Then on some watches I done this with 12 size watches I've been able to swipe pallet stones from other 12 size not even the same company because they may have purchased or stones although Elgin I know at some point in time did make their own tools and had a separate section of the factory that made diamond grinding compound for all their lap and during work. Then when the company got liquidated the diamond division was sold the somebody else in the last I knew it was still running out there but not of course under the Elgin name. Still making diamond grinding compound.   From the 1915 parts catalog you can see all 18 and 16 size pallet stones are basically identical. The difference is what they're made out of and one of them that they didn't policy side in stone probably in a seven jewel watch no one would ever see that anyway. Then you have a new or the old style determines its thickness and you would have of course right and left Then I'm attaching a PDF of Elgin escapement terminology is it is nice drawing to show you the difference between the left and right stones. Elgin watch company Escapement Terminology.PDF
    • The roller table is supposed to be held on by friction. If there is shellac under the roller table it might indicate that an improper repair had occurred prior to this as it would not be held in place with shellac. Sometimes overenthusiastic people re-shellacking the roller jewel will get shellac where it's not supposed to be. Then the picture of your roller it looks kind of damage? It doesn't quite look right it looks like somebody held with a pair of pliers or something? Then your balance wheel has limited quantity of screws? Not necessarily a problem but an indication of perhaps with the other things a prior bad repair perhaps as a guess.
    • Quartz watches like mechanical watches need to be serviced from time to time. In other words the lubrication with time we'll go bad and the watch Will not run or will not run very well in other words oh be slow because the gears are no longer turning properly due to bad lubrication. Then other things bad for quartz watches basically anything dust that normally wouldn't affect the mechanical watch will affect the quartz watch because the quartz geartrain has extremely little power. So looking at your movement up above more than likely you'd have to clean it and lubricated before the new circuit would work.
    • I be concerned if this roller table belongs !   Timegrapher will ask,  where did you get this roller table or balance staff from?   Regs
    • Hi Graham, Welcome aboard.
