I was looking at this mainspring winder set which is for sale.  Does anyone have any experience with these?  Will they handle most wristwatch sizes?  I am trying to get the model number to see if I can find any more info regarding these.
Cheers!
Roger
Sometimes it will be a tight fit. But if it looks like the spring will break then don't use it. Sometimes you can use the next size down crank with the correct size barrel if you are careful.
Omg. I only have one size partly because i buy it separately and not the whole set. So you reckon what i should do is to exchange with the watch shop that i bought from to an appropriate size? Thanks :)
But sometimes the arbor does not fit the mainspring for the correct size barrel and/or the other way round so it is useful to have a set - but even my set with 17 barrels both left and right hand cranks will not fit every mainspring/barrel combination, but the more sizes you have, the more chance you will have that you will have a correct combination.
Cheers!
Roger
Unfortunately, I lost the opportunity to buy the Watch-Craft set shown above.  Has anyone used the K&D 127 or 128 Mainspring Winders shown below?  Will both do wrist watches (I am not working on pocket watches)?  Any insight would be appreciated.
Cheers!
Edited by 64americandeluxe
Here is another set that I am looking at (see below).  Any advantages or cons to using the KD 126,127 or 128?  It looks like the only difference between the 127 and 128 are the barrel sizes they'll accept.  The 126 is the "Robbins Type" but I am not sure what the significance of that is.
Thank you!
Roger
Oh.. anw for some mainspring i managed to fit into the mainspring winder. But when i wind almost gonna complete it and it suddenly pop up and broke the mainspring. Why is that so? Am i doing something wrong? Do i need to flip the mainspring and put it into the mainspring winder? And sorry for this question does flipping the mainspring will causes anything? Thanks.
Hello. Watchcraft mainspring winders can be used to wind right hand and left hand so they are a good starter to begin with. Some mainsprings are left hand wind or right hand wind so the Watchcraft will work , but they are not the quality of a set of Bergeon winders which come in right and left hand wind sets or combined.
I find the most K&D's winders are ok for pocket watches but not all of them fit most wristwatch barrels.
Excellent information!  Thanks very much!
Roger
Not quite certain what happened from your description.
Thanks. Im not sure how to put it in a way. Anw, i will try my best and figure it out and share my success story down here. Thanks. I roughly have the idea of how to..
  • 5 weeks later...
I ended up buying a Watch-Craft winder set like the one shown below.  I should be trying it out in the next week or so.  I know the learning curve is rather steep.  Fingers crossed...
Cheers.
Roger
Hi I was just looking at mainspring winding tools and as someone who is new to this think they are a big expense for the new coming is there anther way of putting in a mainspring with out the tool, or do new springs come ready to fit ?
To be done correctly and more importantly Safely...you really should use mainspring winders to fit mainsprings. There are instances where they are not needed, when the mainspring is held with a girdle that is smaller in diameter than they barrel. These can be installed directly into the barrel from the girdle. But, then again, I usually remove the girdle and inspect, clean and grease the mainspring before installing it. So, I still use a winder set.
There are some deals on used sets out there but I've bought poor sets along with really good sets. It's hit or miss, to be honest!
I bought a used set of Watch-Craft mainspring winders for wrist watches recently and they were very reasonably priced.  I used them for the first time this past weekend (first time ever winding a mainspring) on a mid-1960s Elgin and found the experience quite easy.  I installed and removed the mainspring about 3 or 4 times dry to get the hang of it and then oiled it and reinstalled it.  With the winder, I found the removal and reinstallation of the mainspring much easier than I was expecting (many comments online left me apprehensive about doing this but I was very eager to learn this aspect of watch repair).  For me, winding and installing the mainspring back into its barrel was much easier than trying to align the three pivots on the train bridge!
Cheers!
Roger
  • 4 weeks later...
I'm looking at getting a mainspring winder, the likely candidate being the Bergeon 5355 there's not a lot else thrown up in searches but before I commit is there a better alternative? Occasionally people can recommend a genius of a Chinese alternative to things...
Lee
I have purchased cheap mainspring winders in the past and they have been terrible. In the end I plumped for the 5356 Set. It serves both left hand and right hand mainsprings. But I find mostly that I use sizes 4, 5, 6, 7, 8 and 9
Most swiss movements use the clockwise wound handle and cranks and I find the anti-clockwise handle and cranks useful for Japanese (like Seiko).
There is a special ETA set, but I find #8 is OK for the 7750 and using size #7 with #6 crank (carefully) works well for 2892-A2 and 2824
The rest in the set I rarely use.
  • 5 months later...
So, I'm on the market for a set of mainspring winders and I had a few questions. The main options I can see, in terms of second hand or used, winding tools seem to revolve around:
1. Watch-Craft Bracelet Winders: Sets of 8 in sizes 5mm to 10mm.
2. Bergeon 2729 Winders: Single handle; set of 7 barrels in sizes 0 (5.6mm) to 6 (9.8mm).
3. JC Schilling Bracelet Winders: Much the same as the Watch-Craft ones.
4. K&D 123/128 Winders: Set of 7 barrels and bench vise base. Their sizes tend to be vague but the 128 seems to start from 8mm.
I suppose the worry with 1-3, is how likely is it to need anything larger than 10mm, and how to deal with any left handed mainsprings? Any recommendations or advice? If it helps, I intend working on vintage watches which will primarily date prior to 1970s, so I'm hoping the 10mm upper size on most of these is not an issue for a beginner green looking newbie like me ;).
At present, leaning towards the Bergeon though the Watch-Craft's are more readily available from the US (which makes them more expensive as it happens if you throw on customs + VAT).
Then again, I just spotted a Bergeon set that went for close to £260. Seems the Watch-Craft are a fair bit cheaper overall... Checking the non-local ebay sites to find a few more samples. Looking at older forum posts elsewhere, the prices have gone up in the past year or two for used winder tools.
Edited by PadraicB
I have a K&D winder but do have problems with small watch springs. Releasing the winding notch from the newly wound spring can be troublesome & I have destroyed a few with this problem. It might be because it is an old vintage one but I think it is just the design.
If my finances improve hope to purchase a Bergeon or at least a barrel type winder they seem to offer a lot less hassle.
I don't know guys but in my case I've been pondering about winders and although it would be nice to have a good quality set, the volume I handle doesn't justify the expense therefore I always do them by hand. Somehow it keeps me "closer" to the watch! :)
It is good to know about the K&D glitch, clockboy, since I've spotted some on eBay occasionally and I've been tempted!
I am on the look out too for a set, finances permitting. Anyone want to upload a video of hand winding one and what to or not to do?
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
    • Yes, it looks much better, but at this point the main thing is to make the spring in one plain. so picture from side will show this better. Now it is seen that #1 bending is needed, which is normal.
