Whoa!  It's indicating that, if the fork can last 8 full seconds on that bucking balance wheel, it will make it to the rodeo finals!
Seriously though, I don't own a timegrapher yet (someday when I have more money) but may I guess that those traces maybe mean a bottom balance pivot is doing Chubby Checker's Twist down in that bottom jewel?  It seems like there's a bit of shimmy there.  Badly worn pivot?  Or jewel hole?
1 hour ago, HectorLooi said:
I think it's a bent pivot on the escape wheel.
Is your interpretation based on period of occurance only?    Could this be indicating a wobbling escape wheel?
Educate me gents, please 😩
Random thought I assume you demagnetized it?
The nice thing about the graphical display is the meaning hasn't changed since the first machine spit out paper. Although some of the timing machine manuals you wonder about the mental state of the people who Were interpreting the results. The one I'm attaching is pretty straightforward. Then I snipped out an image of what it probably is.
Then unless you verified the lift angle your lift angle is probably wrong. But that's not going to change the graphical display output only the amplitude.
Timing-Machine-Charts.PDF
  • Thanks 4
For a 1ms beat error, the lines are close together. Can you adjust the scale ?
I have the Weishi 1000 where there are no adjustments.
Big thanks. Will check today
On 1/8/2022 at 8:50 AM, jdrichard said:
From an old picked watch. What is this signal indicating
Update. It was magnetized. Put my small compass on the balance and ta da movement. I demagnetized it and here is the result (somehow I forgot to do this???)
8 minutes ago, KarlvonKoln said:
This is all very interesting.  I will certainly have to get some kind of timegrapher in the future.
At one time sticker shock would be an excuse not to have a timing machine. Anything resembling a professional Swiss machine would usually be in the thousands of dollars and still is in the thousands of dollars. So that would be a good excuse not to have one.
But the Chinese have all kinds of timing machines the recommended ones are the 1000 and the 1900 preferred. Then the pricing of the machines are really interesting in that it depends on who's selling it. Then they can be purchased from the usual places like Amazon and eBay. You just have to pay attention to the pricing usually the US sellers are charging more money Chinese sellers are usually but not necessarily less. Amazon has a 1900 $180 but looks like the seller is in China which explains why the shipping is going to take several weeks.
That attachment should be made into a poster and hung on the wall...
Magnetism in a watch is interesting because normally you would never see it? At least in modern times because the demagnetizer is right next to the timing machine normally. At least it was at school and that's what I was taught. Although I know watchmaker's today that will demagnetized before cleaning after clearing before timing after timing they get really obsessed so magnetize watches on the timing machine not likely to happen or be seen.
A long time ago I was asked to evaluate a small collection of watches with the owners newfangled Chinese 1000 timing machine that I had recommended. He was confused with the reading he was getting. I timed his watches exactly as they were found no attempt to demagnetized clean etc.  Then I was really excited about the opportunity to compare the Chinese 1000 with my witschi watch expert 2 machine.
When evaluating timing machines to avoid complications it works out better if the various timing machines can look at the exact same watch at the exact same time. To understand what I mean there is a sample watch one of the other watches and you notice both microphones holding the watch in a way that you normally would not. Then the results may not always be exactly the same because you can't start both machines at the exact same time. They won't be of evaluating or averaging over the exact same part of the waveform they're always be some variations but this is the closest I can get to both machines at the same time.
As you can see that interesting sine wave effect. It also shows a problem of liquid crystal screen timing machines versus the old paper tape or in this particular case software that simulates paper tape. Although I don't know why on the paper tape simulation there should be two lines and it looks like the watch visually is perfect in beat unless you look at the numbers? But in any case all three are showing the same thing an interesting sine wave which I had never seen before. As we see above once the magnetic field is gone the watch still desperately needs to be serviced but the beautiful sine wave is gone.
19 hours ago, nickelsilver said:
Cool- now adjust the lift angle! should be around 40 degrees, nowhere near 52.
I need to have a sheet of lift angles:). Correct
Excellent way to assess the situation. I simply take a look at the balance on etimer and the w1900 to ensure that the old pocket watch is close to accurate. What did they do before electricity????
The problem with lift angles are there not really needed until your measuring amplitude. They're probably needed if somebody was drawing the escapement but it's not until we get a timing machine or the ability of a timing machine to figure out amplitudes that we need lift angles. Which means pocket watches have no lift angles listed. This means you have to follow the standard method found in the video at the First link to figure out the lift angle. The second link has a chart.
Then somewhere in the discussion group we've  discussed the video up finding a lift angle. I find that if I use a highlighting pen yellow in color did as liquid ink  that it makes a really nice.on the balance wheel looks almost invisible..  At least in standard light with the UV flashlight is fluoresces intently I find it makes it a lot easier  to see the marking.
Then if you get obsessed with lift angles for pocket watches  or you work for a crazy boss who  would like to see the amplitude looking perfect you could make a list.  But if you're making a list do a better job than I did  because having a company with the size just doesn't cut it they had lots of watches typically of that size you should really list the model number or serial number or something.. But still here's a list gives you an idea what pocket watches can be..
https://youtu.be/-Xgcck692js
https://watchguy.co.uk/cgi-bin/lift_angles
ball Illinois 12 size 45°
Elgin 12 size 55°
Elgin 18 size 49°
Elgin 590 16 size 21 J 48°
Elgin GM Wheeler 16 size 52°
Elgin 6 size 62°
Hamilton 12 size 48°
Hamilton 912 12 size 38°
Hamilton 940 16 size 60°
Hamilton 992 16 size 48°
Hamilton 992B 51.5°
Hamilton 992E 42°
Louis Audemar 44°
Hampton 3/0 52°
Illinois 305 16 size 48°
Illinois six size 62°
Lange and Sohne  40°
Longines  pocket watch 35°
Waltham 18 size 38.5°
Waltham 1888 16 size 60°
Waltham 21 jewel 645 16 size 42°
Waltham Crescent Street 45°
Waltham Riverside 16 size 44°
Interesting that there's such variability in lift angles among earlier watches. Any idea why that might be? I suppose if you're manufacturing everything in smaller scales, as well as at the beginnings of the mass production era, there would be less standardization, but I have to think there's a functional reason most modern watches are all in the neighborhood of 52°... What would be the advantages/disadvantages of 62° or 38.5° (the most extreme in the list from a quick glance) over the currently predominant 52°-ish.
Smaller lift angle means less time the balance is engaged with the escapement, which is a goal for good timekeeping. It's easier to achieve with larger movements as proportionally the various "plays" can be smaller. So pocketwatches are often around 40 degrees, wristwatches creep up closer to or above 50. 60 is odd on a pocketwatch but as seen above can happen (these are very old ones). Very small wristwatch movements are often above 55; JLC 101 and 104 are often at 60 and several other of their calibers are 56 or 58.
The Swiss sort of standardized around 49-53 mid 20th century as it was found through practical experimentation that they got excellent results there- with an ease of produce-ability.  There are exceptions, the Omega 321 for example is around 40, while its close cousin the 861 is 50. Also, with higher beat rates the geometry of the escapement changed, with 20 or 21 tooth escape wheels becoming common which lend themselves more to a 50ish degree angle.
This thread caused me to go educate myself on this topic.  I read several papers and watch a couple of videos.  Very interesting stuff.  The old watch timers (Vibrograf) did not calculate amplitude.  When did this become "a thing?"  Maybe the old watchmakers did this visually.
Re demagnetizing watches.  I watch a video a while back...it was an interview with Fried back in '92. One thing he talked about was the issue of demagnetizing watches in the early days.  Was not so simple as it is today!!
One of the problems with lift angle at least American pocket watches is what if they're not adjusted correctly?  I'm attaching a witschi document which talks about lift angle out amplitude is measured etc. Plus I snipped out an image.
Notice the start of lift angle has the pallet fork resting on the banking pin. The same banking pin an American pocket watches that can be rotated? This is man considerably the banking pins after not quite in the right place is going to change the lift angle. But whether or not the change is really going to matter that much. The problem with mechanical watches they are mechanical they're just not that perfect in real life. So as long as you get the lift angle somewhat close it's fine usually.
Test and measuring technology mechanical watches.pdf
Before these newfangled electronic things the watchmaker just looked at the balance wheel and somehow knew what the amplitude was. Which explains one of the reasons I was so excited about getting a timing machine  as I always had a hard time seeing that.
You might find the link below to the PDF interesting. Even though the cover picture shows there transistorized machine it's the identical manual it came with their vacuum tube machine. It's also missing something that came in the original manual? At least it was there in the vacuum tube machine maybe it's not in this manual but it would have to be because?
Notice on PDF pages 4 and 5 talks about the settings and how you can pick up different parts of the waveform. It on the bottom of page 10 it talks what amplitude which is interesting because this machine can't measure amplitude? Is it explains about amplitude continuing on to the next page tells you how to visually verify what the amplitude is. Then on PDF page 12 it tells you how you can measure amplitude in a closed case with a paper tape machine if you have the missing item? In the original manual was a  clear plastic printed page that you would overlay on the paper tape and you can measure in milliseconds how far apart things more. So combined with the knowledge that you learned from the rest of the manual you can figure out the amplitude of a watch with a paper tape machine.
http://www.historictimekeepers.com/documents/Micromat.pdf
You can measure amplitude using Slow Mo on you iphone.  Most accurate way.  You can also measure the beat error as well by looking at the left-of and right-of center when the balance stops.  Should stop in the exact same place on each opposing side.  Which means the balance has swung clockwise and counter clockwise the same degree distance.  Just saying
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
