Have been reading with interest the threads about watch cleaning machines and I thought I'd post a pic of mine that I purchased on eBay a few years back, old L&R Master, it was in a pretty unloved state when I bought it, motor ran, heater did not and paint finish was all chipped, worn off and just looked not nice, I paid $130 for it as I knew it could be brought back to life with a little love and attention.
I re wired the whole unit (original looked downright hazardous, threadbare fabric insulation) and rubbed down paintwork and sprayed unit and jar lids with grey hammerite paint, replaced the bulb inside the red display switch and the heater was operating, (the builb acts as the fuse for the heating element).
Spent under $20 in Home Depot for everything that I needed.
Hoping this might help someone who has been looking to get a machine, it really was a pleasing job fixing it up and it's a great little machine that I now love dearly.
  • Like 6
Very nicely done,Brian3. I think I have just as much fun restoring the old tools as I do the watches. One of my other hobbies is restoration of antique radios. A lot of the skills from that hobby transfer over to the restoration of the watch tools, especially the electrical side and the polishing and cleaning. Good choice on the colour and lucky the faceplate survived in such good shape. I will have to settle for an ultrasonic cleaner for the time being as I would never be able to justify the purchase price for the amount of use it would get.
Ron
Thanks all.
I don't use it a great deal Pip, perhaps averages out one cleaning session per week, just depends what I happen to be messing around with at home.
Not really sure of advantages over an ultrasonic, the machines at my work have it built into the cleaning cycle if you want it, this old boy obviously doesn't but parts come out surprisingly clean and I'm real happy with it, and it's a small unit that doesn't take up much space which is a bonus. Perhaps more knowledgeable people here on the forum could answer your question.
Brian
Great work Brian !
I just bought a L&Road variomatic that looks terrible but I have it running now.
I doubt mine will look as good as yours but I'll give it a try.
I can't use it yet, it did not come with a basket. On the hunt now for one.
Thanks for sharing,  Tom
Thanks all.
Brian
Thanks Brian, I find stuff like this fascinating.
  • 4 weeks later...
  • 9 months later...
I've an L&R cleaner, the style with the three jars and heater.  The lids for each jar,of  a sort of bakelite material just sit on top of the jars with the edge of glass in a ring groove recessed in the lid..  A while ago I made a batch of solution (home brew that worked well enough, next time I want to acquire the proper chemicals for a better cocktail) but after some time about 50% evaporated from each container and what was left was a lot less effective.  I conclude that its the VOC's with the umph that were the quickest to depart,and the evaporation was possible because of the very poor seal of a plastic lid just resting on top.
Bad enough to lose the home brew let alone the crazy expensive commercial stuff - at $50 US per gallon.    A pro might use it often enough that frequent replacement does matter, but as an amateur I need it to last as use is infrequent.   I could drain and store in seal-able containers, but that's a pita to do every time.
So I want to seal these jars.  Any ideas?  Best I come up with a thick disk of steel (3/4") with a treplanned groove to fit the glass  rim.  With a rubber gasket glued in the bottom of the groove and basically the weight of the disk provides the seal.  I actually cut disks today, but it seems like a bit of blunt object solution.
Better ideas?
All the machines I have had in the past the lids screw on with a seal fitted inside the lid, this prevents evaporation and vapour from leaking. I would say what is happening with your machine you do not have the proper jars or the seals been damaged. I see different jars come up quite often on ebay. I just used to store the fluids in there containers in a shed away from sun light.
My L&R also suffers with evaporation loss. I found if I cover the machine with an old towel this helps but does not totally eliminate the evaporation. I am sure I have the original jars but no seals on the top covers. I will investigate.
37 minutes ago, oldhippy said:
I remember one of the machines the seals were cork.
The older Elma machines use cork. Pain in the ass as when the cork degrades, you get fragments fall in the fluids. Not sure about the newer ones but I suspect some kind of rubber seals are used now.
I did have one of those Mark at some point, can’t say I had any problem and it was quite old.
1 minute ago, SSTEEL said:
I purchased new jar screw tops from cousins as a couple of mine (ELMA) were cracked, they come with a cork seal ring.
36412926896_e12d0eca5a_o.jpgELMA Jar Top by S STEEL, on Flickr
Yes, and I'll wager they wont be available for much longer as the RM90 and Super Elite are completely discontinued now in favour of Elmas new jobbies.
5 minutes ago, oldhippy said:
:D
I always used L & R cleaner and rinse. Don't know if that had anything to do with it, also it would have been back in the early 80's so it could have been been quality
To be fair - the only reason I worry about cork these days is when I break one trying to extract it from a bottle - always a bummer when that happens!
    • As far as I know, the only time an epilame treatment has potential drawbacks is when something is rubbing on the treated part w/o lubrication in between creating abrasive dust. That is, I don't believe in the method of "running the watch to make a groove through it first in the pallet stones where the lubrication is then placed". So, I think the rule would be; do not epilame treat parts where rubbing is going on without lubrication. Other than that I don't think we have anything to worry about. That said, I'm not an expert, and I'm always happy to learn more. Has any other repairer than Alex suggested or explained the "making-a-groove" method? My impression is that it's just something he constructed in his mind. I have not perceived it as a generally practiced method. Again, I could be wrong!
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
