Here is the Seiko 6602 with a different dial and watchband along side a Vintage Hamilton Pan Europ I am working on . A new crystal is on the way for that one and I am thinking of sending the dial to someone for a professional refinish .
Excuse my inferior pics . I will have to get a better lighting set-up .
I would like to take my hat off to Jules Borel & Company for their excellent customer service . I ordered 2 gold tension ring type crystals for the Hamilton Pan Europ from the company . I did my measuring of the original crystal and case per Mark's great video on " How to fit a watch glass" . I ordered 2 per his suggestion in case one was too loose . Well , Jules Borel quickly filled and mailed my order , which was only $12.35 total for both crystals...pretty good for tension ring crystals .
  When both arrived last Saturday the number on the packaging was correct , 272 for 27,2mm and 273 = 27,3mm ., but the actual crystals were both too small being  26.72 and 26.82 mm respectively . I checked and double checked everything , my crystal and case , the new crystals and package text , and the info for these on their website and yes ,they were too small . I emailed them Saturday with all the info and today Monday I received a phone call and Email acknowledging  my Email . They are sending me 2 new crystals that they have made sure to measure at no cost to me and told me to keep the original 2 that they sent me . They are not sure how the first 2 got mislabeled but they will check with their supplier .
  Best of all the CS Rep . told me that they aim for customer satisfaction no mater how large or small the order is .
This is my first post to this forum. I have very rudimentary watch repair skills and only a modicum of knowledge about watch repair, so please have some forbearance. I have always heard that watch dials cannot be cleaned, but this watch has tempted me to try. I have attached a picture of the gold filled Elgin that I want to clean. I know that the picture is bad, but perhaps you can the black smudge around the numeral 1. Additionally, the gold numerals are dull and have a smug end appearance.
Here are my questions. Is it indeed always hopeless to try to clean a watch dial? Is there a way that I can brighten up the gold numerals?
Thanks in advance.
Hello BIll3 welcome to the forum!
Oh my my...be very careful with using any liquid on a dial. I would advise against any type of liquid-based cleaning!  The only thing I have used to give a dial a little brightening of the numerals and markers is a fresh, unused piece of Bergeon grey premium Rodico premium (no. 7033) or if you don't have that, a new piece of the regular green Rodico (no. 6033).
Even with Rodico you need to be careful not to rub the dial...only use a "blotting" method where you simply dab the dial in a vertical motion without any lateral movements. II would still emphasize caution because even Rodico can leave smears particularly on dark dials. I ruined a black Bulova dial because I rubbed it with Rodico. The resulting radiating swirl marks looked identical to those left on a black car that has been rubbed with a circular buffer.
J
Hi everyone.
I found this post and I couldn't believe my eyes.   I have always been ultra careful with dial faces.  This guy uses car polish and the results were amazing.  I still don't think I would try it but its certainly interesting reading.
http://forums.watchuseek.com/f2/jlc-memovox-given-new-life-long-230701.html
I have always just left any dial face alone for fear of any damage.
Jim
Mark I agree whole heart-idly  with you.  I was astounded with his results.  Perhaps ignorance is bliss.   It was a bold move on his part.   Now I must try it on an old dial face.
Sincerely,
Jim
I have seen that green hue before especially on movements from India    it dries like hard candy    strange stuff.
Jim
What a watch to experiment on [emoji33]
Lovely looking dial afterwards.
Hmm, wonder if I dare use that stuff on dads Omega [emoji9]
Edited by ro63rto
Possibly the old varnish. If the print is under the varnish and sound this method should work but great care needs to be taken. I have found many watches to have the print on top of the varnish and tends to come off far to easily.
Got this old Smiths Astral in the other week:
Although the pic doesn't show it too well the dial was in a right state with varnish lifting, discolouration, water damage to edge etc. Took the plunge & dipped it in HG silver fast shine (Goddards silver dip is the same I believe). Most of the minute markers had lifted with the flaking varnish so the rest were removed. When dry sprayed with acrylic varnish.
The result:
Edited by Blacklab
By all rights that JLC should have been ruined... such a beautiful timepiece too.
Nice work Blacklab, you guys are always impressing me with what you can do with dials, I've never made any serious attempt to restore any dials before, I'm too scared of it going wrong, but i have plenty of scrappers, would definitely be worth trying some of the methods I know of.
Good morning guys. New to the site and looking forward to the help and learning more. I'm cleaning a Seiko 6102 and have a dial where the clear coat has partly delaminated from the face possibly from past moisture incursion. The raised parts have a nasty appearance under, possibly dust but mainly the difference of colour between cavities and where original contact remains. Anyone had success in removing the clear coat and if so, how did you do it?
Thanks in advance
A warm welcome to the forum Cunningham. I can't give the advice you require for a severely damaged dial, but hopefully someone will pitch in with good advice. :)
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
    • For years I've done it the el-cheapo way (read: cleaning by hand). Bought a 2nd Elma S15(H) ultra-sonic, including proper cleaning-fluids (Elma WF Pro (cleaning) & Elma Suprol Pro (rinse)) and entered a complete different cleaning world. These cleaning fluids are none-water based and not that easy to obtain. Initially I bought these fluids in Germany "SKSONIC" (www.sksonic.de) but last year they stopped shipping international. Perhaps they resumed international shipping? You can always ask them. You could also ask @VWatchie, he lives "next-door". As for the fumes; I use the ultra-sonic in my garage, partly for the fumes, but more for our dog ...... he goes "bananas" when I switch on the ultra-sonic. Oh, next on your list (if you consider watch-repair as a long-time hobby), a Microscope (up to 50x is enough).  Pegwood leaves, observed under the microscope that is, whole tree-trunks behind 🫣 Ultra-sonic, in combination with proper cleaning fluids, takes care of the cleaning.
