Hello from beautiful Spring, TX
Clrncd
Hello everyone. Retired guy here finally made home in Texas where my watch love brought to me a "keeps on ticking" Timex from the 1970's or previous. Wondering if anyone could lead me in correct direction to service meaning dissemble, lubricate, and re-assemble to save me $400? Would love do this myself as local Role* practitioners confirm to me "fine watch, (yet) you will still pay the premium price." That is 10x purchase price! Thank you in advance any information y'all can provide.
Welcome. Disassembling Timex watches is not recommended for a beginner, because it requires re-assembly, which is not easy or conventiona. You will find some reasoning on why in the below, and in various more discussions.
When it's about servicing low material value watches, the first question should be "is that really necessary?". If it does not keep good time, an attempt to demagnetize and regulate should be made first. Since the "right" tools and environment to do that "almost professionally" can set one off €200 easily, that sets things in perspective I think.
$400 to service a Timex in Texas?  Say "Howdy partner" to TEXAS _ MO!
Truly I appreciate the plethora advisory and links to the video. One my past lives was "auto-mechanic." Clearly- I do not have the steadiness of motion to accomplish these tasks. The gentleman in the offered Mickey dissemble video has an adroitness that I do not plus a remarkable patience.
I conclude that my avocation in watch repair shall remain fantasy but will not discount wearing a shiny watch missing only one complication (day). Thank you all.
Don't be put off by watchmakers doing intricate manoeuvres in seconds, either they've spent their lives learning those skills or the video is edited to pretend that they have. There's plenty of methods to do things right, if you have the patience.
  • 2 months later...
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
