Total Newbie confident but no skills
Hi All
I have been watching Watch repairs on Youtube for some time and now feel its time to have a go.
I have a 1976 Marlin Timex with a M27 Movement, this is an old Family watch. It has a cracked crystal and has no life coming from the main spring. i have would it up and released the tension with the click but nothing.
I was hoping to replace the crystal and try cleaning the movement ( with the little you can easily remove, taken off) and then if no joy with he movement replace it with another.
 Also I bought a 1940s Wyler very cheap which has a cracked Crystal and a broken Crown stem. I am keen to strip this down and clean then try to rebuild it.
My main question at the moment is where is the best sites for replacement parts?
All help welcome
Thanks
Richard
Welcome to watch repair and the forum.
Timexes aren't the best watches to start learning watch repair on. They are highly unconventional and spare parts are hard to find. Many members here would advise you to start with pocket watches and China movements.
After you become comfortable with conventional watches, then maybe you can try repairing quirky Timexes.
Hello and welcome to the forum As Hector said the timexe's are not the easiest to start on but on the plus side you only need to remove the balance to clean them. I have attached two documents you might like to read before embarking on your venture. Also added is a tool list which may be of some use for you   cheers.
27 (1).pdf 1961_Service_Manual (1).pdf 1831920544_ToolsfortheHobbyist.pdf
    • Got it thank you! I'll steer clear of the lower jewel count movements until my skills are a bit better. I'm literally brand new to this
    • Depends where you are with repairing, watches like you have just mentioned  the Smiths, Ingersolls, Services are often pin pallet watches with low jewel counts, not impossible to fix but often quite difficult due to having more wear than a fairly standard 15 or 17 jewel movement. Saying that you may be lucky and pick one up that was never used much. As an example i spent a few weeks on and off getting the most i could from an old Smiths Empire, that did actually finish at within 2 minutes per week that could be improved further now i know it is fairly precise but not quite accurate . Sekondas are good practice pieces at around a tenner, though some folk call them rough but robust.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
