So what do you think about this?
oldhippy
Good morning
It's a strange looking clock. the case doesn't look right to me but having said that the front and back plates have been grooved. The bell doesn't look original. On his web site he claims they are Fully trained and hugely experienced horologists but the taper pins on the front have been cut with side cutters and not finished off to an acceptable standard, in my opinion.
Must say ojojojoj the steampunk version of a clock from the series “The league of S.T.E.M.”, hence the price.
@oldhippy, before you pop away a post like this you have to put out a warning sign, someone
might just out of chock pop their eyes out with a couple of forks, or just lose their lust of living ?
Forgott to put out the link of the three clockmakers responsible of this creation.
Edited by HSL
So sad.
Parts of that clock seem very old.
Modern base, 20th century bell, screws on the back of the dial are modern.
The dial looks like something I could make and that's not a compliment.
I would be interested in seeing it up close, but as to buying it over the internet for their starting price I'm running away very fast.
It's definitely a talking piece! it would make a good example of what to look for when trying to find genuine antique clocks - or rather what to look out for! Hopefully the price will scare everyone away as it looks like a lemon to me!
In other words,  a trigger warning ?
I think this is shoddy miss match. I'm not sure if it is even English, to me the bell is not right, it is more like the design of a Dutch bell. I think the whole bell bracket including bell is a replacement. The screw that hold it is a cheese head screw, the others are not. The alarm hand is a replacement. He says the board it sits on is not original, that is definitely right. Wrong screw fitted to the balance cock not original, what a shoddy steel pin fitted to the hole, never even bothered to trim it up to the correct size, it should have been brass. The screw that holds the calendar wheel in place is again different. The two brass? finials are odd.
There's a lot going on there.  I know more about watches than about clocks.  But intuition would have me give that piece a wide berth.  It kinda looks like someone wanted to get it running well enough to *say* it ran, so it would sell.  So they raided a parts bin first, and then cut out a seconds hand with some tin snips, made a steel taper pin and guessed at the length, and slapped photos on Ebay.  That's a guess, but that's what my intuition would be whispering to me as I looked at the pictures.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
