Favre-Leuba 253 Service
On 2/14/2017 at 11:01 PM, icius said:
Tracy.  I think it is working again.  Maybe it was because I haven't logged in in quite a while?  When I click it it immediately downloads it rather than trying to open it in the browser.  Let me know if you are still having trouble.
Thanks, the link works and I can download the pdf. However the pdf cannot be opened?? Maybe the file is corrupted?
I have tried opening it no more than one computer. I also tried opening it using Adobe Acrobat Pro--on luck?
Can you check to see if it can be opened--maybe update the pdf?
Thanks, Tracy
  • 1 year later...
Good afternoon,
I felt like I HAD to register and comment having found this doc online.  Wow.  I was desperately looking for some images of an FL movement very similar to this one as I am currently in the process of re-assembling one (my first movement assemble pretty much from scratch), never in my dreams did I think I was going to stumble upon a doc like this, which basically takes me though re-assembling the thing step by step!
I plan to use this doc extensively throughout this little project :)
Thanks SO much.
  • 8 months later...
  • 7 months later...
1 hour ago, AaronIkonen said:
I recently got this watch and it happened that the stem fell off.  how does it lock in place?
Please do not  hook onto other topics just because you own a same watch. We have a section for questions as well one to introduce oneself, which is always appreciated.
Anyway I recommend that you bring or ship it to a competent repairer.
Edited by jdm
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
