Hello from Australia
By nickelsilver · Posted
Hmm, well, using the faceplate and boring with the slide rest is I would guess an order of magnitude more accurate than simply drilling or reaming. So in a watch, that makes a difference. The project I mentioned above had arbors like 0.70mm long, with large diameter parts attached, so any misalignment of the jewels would cause a large tilting error of the part. -
There's not enough information on your original post to determine the movement and what the correct spring size should be. If you're confident with your measurements then the GR6573 looks correct apart from the end termination, again, without more information I can't assist further.
Could you explain it to me in a easier way what did you mean shimming cock word do what you mean setting house is that the cap jewel
Thank you. Please see earlier post here about same watch
