Loose Hour Hand Tube, How Do You Secure?
I am coming across more, and more loose hand tubes these days with the various watches I have in for repair, and was wondering what methods you use to secure the hand tube to the hand to prevent it from spinning again?
I have tried broaching, pin vice etc, but the success rate is 50/50 right about now.
new hands...!
TBH..nothing makes it back to perfect.. metal, once expanded will always want to stay expanded.
Example with sheet metal (panel beaters).. it is only with applied heat and selective cooling (heat transferred from the surface to the head of the hammer/dolly) that dents can be repaired, not exactly applicable for watches.
If every watchmaker used proper hand-pullers and correct hand-setters then this problem would not exist! its when they get at an angle that the tube expands beyond limits.
Anil
Micky. If the hand is loose then I mount it in a pin vice and tighten it little by little until the job is done. I have a very high success rate this way.
I have tried that Mark, and normally its ok, but for example, a hand I have right now, it has a large face polished area and I am very worried if I sneeze it anymore with my pin vice it will show a buckle in the finish.
That's a difficult one then. I have not tried this, but my experiment mind is kicking in, perhaps coating the inside of the hour hand tube with an epoxy. The when it is fully hardened to broach it to size. This may possibly work and would be non-destructive.
Its the tube of the hour hand, its loose, and the tube fits the pinion perfectly, but the hand itself spins due to being loose off a the tube, its a two part construction, the hand itself, and the tube, the tube has a lip on the underside, I could put a dot or two of adhesive on there I guess.
If you have a lathe and a staking set, you could make a mandrel to allow you to nip it up with a suitable punch. It certainly wouldn't take much to tighten it.
I just had a second thought, could you work some loctite retainer into the joint then clean off the excess? Once set then fit the hand. If it worked there would be little chance of any blemishes on the hand.
Hmmm interesting . Two part construction , so the hand on the hour hand slips on the on the tube that pushes down on the pinion . Like the rivet that binds them has come loose . So as was suggested you would have to stake it back together or use something like lock tite or [eek] epoxy .
Could the tube be split ?
  • 4 years later...
    • This is not rare at all, the dial code and case code don't usually match.
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
