Heuer Quartz running fast
20 minutes ago, JohnR725 said:
Just to be clear here mechanical issues with the electronic components or mechanical issues with the watch itself in other words the gears the stepping motor etc.
Mechanical issues with the train wheels and stepper motor, cannon pinion, and hands.
Crystal is fine. IC is fine.
An easy way to disprove your theory would be if somebody would replace the circuit board. But I look forward to hearing your theories on the mechanical issues that cause the problem that's occurring.
4 hours ago, AndyHull said:
You just need to find someone who knows about making very small (and very basic) oscilloscopes.
https://github.com/pingumacpenguin/STM32-O-Scope/wiki
https://github.com/pingumacpenguin/STM32-O-Scope/wiki/Construction
Yup.  These are my two largest scopes and my smallest.  I have a total of five.  As you see, the little one could be strapped to the body.
Thanks to everyone for your thoughts on this.
I have looked at the test point located by JohnR725 using a PC based PicoScope. It has a square wave at 512Hz when the watch is running normally.
As I posted earlier I have been able to get the watch to run erratically by warming it up in an airing cupboard.
So in order to determine if the cause of the issue is movement or heat I have done some further experimentation.
By putting the movement on a warm radiator (40-45C) I can get the erratic seconds hand stepping. Rechecking the test point also gives 512Hz. So it doesn't look like it's the crystal or the early stages of the divider chain.
I then put the probes across the coil and could see the alternating second pulses during normal running as shown on the lower trace in the attached picture. After warming up the watch the trace changes to the upper picture. As you can see the voltage is much reduced on the positive pulse. So it does look to be electronics/coil related.
I guess  my nest move is to get a replacement circuit board and coil as suggested.
Regards, Kim.
Regards, Kim.
Excellent debugging.  It looks like the output driver in the IC has a problem.  OR, there is a cold solder joint along the path between the IC driver output and the coil.  Can you post a picture of the circuit board?
Until this morning, I had not watched your video.  Did not realize that static operation was also erratic.  So my theories were based on my false premise.
At any rate,
1) the crystal is good
2) the divider chain is good
3) the IC output driver could be bad
I am <not> NOW placing my bet on some resistance in series with the coil.
Yesterday, I fixed an electronic watch that turned out to be essentially an open circuit due to poor  (perhaps oxidized) connections.
Edited by LittleWatchShop
corrected "not" to "now"
Hi LittleWatchShop,
I have attached a picture of the circuit board. I have also looked at it under a microscope and can't see any cracked tracks or dry joints. I did try loosening and retightening the screws before removing the board, but the problem is still there.
To fully eliminate the possibility of movement when wearing the watch I took it for my daily covid constitutional on the outside of my jacket, and it kept good time. So it does look like temperature is the cause. But it does seem strange that such a small rise (20C to 30C or so) is enough to cause this problem.
22 minutes ago, KimBowers said:
Hi LittleWatchShop,
Temperature seems to be the culprit.
When temperature goes up, resistance goes up (generally). But there is no obvious place where resistance is in the way of your contacts are good.
Are the battery contacts clean and engaged well with the battery?
Is it a fresh battery?  I know this is a dumb question, because you seem very proficient with regards to electronics...but I have been fooled before.
Other than an interesting shade of blue which tells us who made it you didn't give us the numbers?
2 hours ago, KimBowers said:
Looks like I'll have to find a replacement circuit board and coil assembly
When you get the circuit board make sure you get one that looks similar to yours. As far as I know all of the 963 whatever circuit boards should interchange. But when you look at the cross reference sites they don't indicate that. That's because there were variations. So originally this watch came with flexible circuit board into pieces. I have attached photographs showing this. Also needed a screw with insulating washer to connect the coil to the rest of the circuit. I would stay away from the flexible circuit boards.
The flexible circuit boards are an interesting design as I'm not entirely sure how they made them. I'm also attaching additional photographs of the women's version . You notice that the conductive material can bridge over gaps which are typically don't find in standard circuit boards. To hold the quartz crystal in place there's a part of the circuit board goes over to hold it in place. In the case of the smaller women's circuit board this did not work very well. You'll notice the connections to the quartz crystal itself bridge between the circuit board in the crystal. But in the case of the women's and one of the pictures shows this it would break. That would cause a variety of interesting problems. Fortunately the company is working for was ordering so many of these we just put a request in the Switzerland and a droppable epoxy on the other side prevented the crystal from hinging and breaking its contact. But it does show flexible boards are not a good idea and watches.
Tektronix 465B, Tektronix 2440
Tektronix is the "gold standard" for oscilloscopes.
My other Tek (not shown) is a TDS 2020b
Interesting pictures of busted PCB connectors.
The 2440 was given to me.  I never use it.  I plan to give it away when I find the right person.  I use the 465B as a curve tracer--nothing else.
If I may stick my 5 pence worth in,  Taking a step back to the mechanical watch which has a fixed gear/wheel ratio and is driven via the mainspring. The gear train once the spring is wound will run down fast to start with and diminish as the spring weakens and eventually stop as it runs out of power. To control the power rush we introduce the escapement with a controlled oscillator (the balance). Now the power is controlled and the watch runs down in a controlled manner, at a rate set via the balance spring eg 28000 bpm. If we now remove the spring an fit a battery for power and a circuit to control the power output, a crystal that oscillates at 37.678 Hz. and the circuit controls the out put passing it to the stator,  the stepper motor at 1 Sec pulses,  the gear train of the watch will step once per second controlled by the out put of the oscillator.  Oscillators can and do stray from the given frequency ( I have changed a few)  causing timing issues. Forgive the diatribe just trying to get my head round it. My best bet is the circuit and or the oscillator.
As the watch has been left in a drawer for a number of years prior to a new battery being fitted, my money is on nothing more complicated than dried up lube causing the problems, shown up when the watch is warmed up by wearing it. I have about 50 pre 1980 Seiko quartz analogue watches and this is a very common problem with watches that have been stored for a number of years.......
Dried lube can make a quartz watch run fast? How? That's the problem the OP is having.
7 minutes ago, jdm said:
Dried lube can make a quartz watch run fast? That's the problem the OP is having.
I missed the degree of error (10's of seconds a minute) in the original post but 'double stepping' of the rotor does sound more mechanical related than the possibility of the oscillator running fast, as surely that would still single step, just at a faster rate than once very second?
This is intellectual discourse among very knowledgeable people seeking an answer to this puzzle--a fun exercise.
For the quartz watch of this vintage, I think the circuit is pretty simple.  Oscillator, divider chain, driver.  There are probably some control functions as well, but the "drive train" consists of these.
The oscillator comprises 1) a quartz crystal, 2) an amplifier, and 3) two capacitors (can be parasitic elements). In order for the oscillator to oscillate, the phase shift from the input of the amplifier to the output of the crystal/capacitor must be 360 degrees at an amplitude greater than but close to unity.  This requirement for oscillation is the Barkhausen criterion.  The crystal has a very high Q where the Barkhausen criterion can only be satisfied at a VERY narrow range of frequencies. Typically for a crystal of the type here, the range is +/-100ppm.
The crystal drives a divider chain consisting of fifteen flip flops configured as toggle flops.  They divide the oscillator output frequency to 2^15 yielding a 1 Hz output frequency.
The output of the divider chain then goes to a coil driver circuit which is configured in a fully differential fashion.
What can go wrong?
The oscillator will oscillate at 32768 Hz +/- 100ppm or it will not oscillate at all.
The divider chain conceivably could (due to a circuit failure) skip one or more toggle flops.  Generally these circuits have a feature built in for test purposes allowing for the portions of the divider chain to be bypassed during test so that the test can be accomplished faster than the one-second output would otherwise require.  I think this would be rare, but possible.  If the divider chain is broken, no output would be provided to the driver.  So, it is possible that under some conditions, the chain is shortened and the 1 Hz output becomes 2 Hz but not 1.2 Hz.  If the shorting occurs intermittently (say once every five seconds) then the average output of the chain could be a non-integer value.
Next up!  The driver.  The driver's purpose in life is to provide the energy to the coil at the rate dictated by the oscillator and divider chain.  If the driver is weak in one phase--not sure how the stepper motor would respond...this is an electro-mechanical component.  Maybe a weak positive pulse could cause the stepper to make a partial rotation and then the next negative pulses cause it to jump two steps.  I cannot visualize how this particular watch is configured, so am at a bit of a loss.
If this watch were running slow, I think there would be multiple candidates for the problem cause.
What can go wrong?
Here is the driver stage
Can someone provide an illustration or photo of the actual stepper of either this or similar vintage watch?
When the rotor sees a magnetic impulse, it will turn.  What stops it?  Well, if the magnetic energy is applied long enough for the rotor to settle to resting state, then magnetic energy itself stops it.  However, if the rotor only receives a magnetic impulse, then there must be a mechanical feature (like the keeper on a calendar ring) impeding the rotor from running past the point where it should stop.  THIS WOULD speed up the watch if it is not impeding properly.
Ideas?
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
